Corvette C7 Z06 Aero in Carbon Fiber
So you’ve picked out a Corvette C7 Z06, and you’ve already made up your mind that it needs some improvements. You’re fine with the performance, and not too interested in changing the interior for any reason. So what kind of improvements do you make? If you’re looking for changes that are a bit on the subtle side, there is a solution. It just so happens that this stage 2 carbon fiber aero kit should address all of your needs.
With side skirts and a front chin splitter in gloss carbon fiber, the kit really adds to the aggressiveness in such a way that it looks like a factory installed option. It matches perfectly with the lines of the car, and has absolutely no hints of distastefulness. It also appears to be subtle enough that parking garage entrances can still be taken without worry of scuffing up the shiny parts.
Also available in exposed carbon, the kit, from supporting vendor Carvaggio Corvettes, is set to look good in any color.
