What adapter to use for C5Z
Installing an aftermarket HU in my 2001 Z06 and will be using an aftermarket amp/speaker combo. Which wiring adapter do I use?
- Travis
- Travis
If you're gutting everything you don't need one. Just use the 3 wire pigtail for your power source, it's usually taped in the upper left corner of the fuse box area.
The ROEM is only needed if you want to keep the stock door subs functional. All a new HU needs from a C5 is the 3 power wires in the footwell. If you're doing all new amp/speakers they get everything from the HU, so no interface adapter needed
You will still need an antenna adapter and mounting plate
