Alignment and the "stick out" factor
Location: Are you fat because you're lazy or lazy because you're fat? San Jose, CA
Cruise-In X Veteran
St. Jude Donor '09
I'm looking at buying a set of CCW 505As in 19x10 and 19x13. The rears have a 345/30 on them, 9.875" of backspacing, 73mm offset. I'm going to have some tubwork done, but am still concerned that the top of the tire will be out past the fender.
Would adding 1 or 2 degrees of negative camber to the rears move the top sidewall into the fender say, 1/4"?
probably not, since you add camber by moving the bottom out, not the top in. Of course, since the upper pivot is not as high as the top of the tire, the top will tip in a little, but not much.
Of course, if you only need 1/4", it might do it.
Quite possible. But a few other questions.
WHy are you getting 19" wheels?
18" wheels are more user friendly and are several pounds lighter. Plus rubber is much less expensive.
What are you going to use your car for?
auto-X ? track days ?, racing? or combination?
once you know what your going to use your car for, will help with the alignment.
Cruise-In X Veteran
St. Jude Donor '09
90% street. It will see a few Auto-x events a year, like 3-5 tops. I'll probably put some race tires on the stockers.
I wouldn't be auto-xing on the 19" CCWs anyway, way too expensive for rubber.
I brought the question in here because you guys know about alignment.
I just don't want to spend $4000 on a set of CCWs and have them sticking out and looking ghetto.
