Anyone run a Breay Krause harness bar w/ a Hardbar seat mount? Downbars too long now
Old 06-13-2007, 10:45 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default Anyone run a Breay Krause harness bar w/ a Hardbar seat mount? Downbars too long now
The BK down bars are designed to work w/ a stock seat... the bottom part goes over the stock seat stud over the seat rail.
With the harbar seat rail in it makes the bar sit too high to line up w/ the hole in the main horizontal bar even w/ the top heim-joing adjusted all the way short.
I wasted 2 expensive drill bits enlarging the bottom hole to fit over the Hardbar seat adapter stud as it's larger... finally got it.
Any input? I still have the rigth side down bar in and will run it as is.
Old 06-14-2007, 07:09 AM
GO_BLUE_VETTES
GO_BLUE_VETTES's Avatar
You have to pound the bottom of the BK downbar flat and put it underneath the hardbar seat stud adapter. Try to shape it a little bit so it follows the contour of the floor pan. Cut a slit in the carpet and to tuck the flat underneath it.
Old 06-14-2007, 07:36 AM
AU N EGL
AU N EGL's Avatar
Brian. I did not use the B-K down bar on the drivers side. It would not fit.
Old 06-14-2007, 08:00 AM
Cobra4B
Cobra4B's Avatar
^ Thanks... I'm just going to leave it out instead of further molesting it.
Old 06-14-2007, 12:40 PM
Lancer033
Lancer033's Avatar
same here
Old 06-14-2007, 01:22 PM
Cobra4B
Cobra4B's Avatar
^ Good to know... I'll leave it alone.
To Anyone run a Breay Krause harness bar w/ a Hardbar seat mount? Downbars too long now
Quick Reply: Anyone run a Breay Krause harness bar w/ a Hardbar seat mount? Downbars too long now
