Offroading...
Old 07-02-2007, 01:37 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default Offroading...
A few more pics from the track... turns out they got my "off" when trying to trail brake into turn 4 at VIR
Old 07-02-2007, 01:47 PM
Olitho
Olitho's Avatar
I have never done that before....
Old 07-02-2007, 03:16 PM
Z11409
Z11409's Avatar
Keep spare rocker panels close by-front splitter on C6Z will both cut grass and plow rocks.
Old 07-02-2007, 03:20 PM
gfacter
gfacter's Avatar
Turn 4? That's a throw away corner
Old 07-02-2007, 03:31 PM
Cobra4B
Cobra4B's Avatar
Correct... but sometimes you've gotta try new things... like sliding through it
Old 07-02-2007, 03:37 PM
gfacter
gfacter's Avatar
Well, just be very happy the grass was dry.
Old 07-02-2007, 07:11 PM
the blur
the blur's Avatar
were you running the active handling ??
Old 07-02-2007, 09:13 PM
jrz1
jrz1's Avatar
At least you weren't the vette that hit the tires between 3 & 4. Ouch. Beautiful night here in Danville. Great day. Wasn't too unbearably hot.
Old 07-02-2007, 10:11 PM
GreyGT-C
GreyGT-C's Avatar
i was on the observation deck when he (black C5) hit the tires and armco... kept the brakes to the floor the whole way into the tires/armco....
Old 07-03-2007, 01:00 AM
Olitho
Olitho's Avatar
I was not there and I did not see it.
I am curious as to what you suggest he should have done?
Oli
Old 07-03-2007, 08:24 AM
Cobra4B
Cobra4B's Avatar
Nope... don't run AH... it won't let you rotate the car.
True... when it's wet out I don't try new things... it was a completely controlled off. Once I knew I wasn't staying on track I just drove it off.
I heard about that.. didn't see it.
I take it you're suggesting he could have saved it if he'd kept some throttle and steering vs. going both feet in?
Old 07-03-2007, 11:03 AM
Mikelly
Mikelly's Avatar
Damn Brian, Get a John Deer if you want to do a little agricultural work!
Glad you didn't bend anything!
I had flashbacks to my "off" at T10...
Mike
Old 07-03-2007, 11:06 AM
GreyGT-C
GreyGT-C's Avatar
Oli
he was in a sideways/forward slide.... a lil throttle and steering input would have changed his trajectory enough to keep him out of the wall.IMO Not suggesting NOT going both feet in when you get into trouble and trying "to save it", but don't quit driving afterwards, which is what i looked like from my view point. I agree he did the right thing by going both feet in, but after the car was back under control and slowed down greatly... take the car under your control. That's also VERY easy to say while standing on the observation deck... i may have bought a piece of Armco in his situation too.
Old 07-03-2007, 08:17 PM
rushon
rushon's Avatar
Default C5 between turns 3-4
I am the driver that hit the tires/armco. I lost control under power in 3rd gear. I did put both feet in, and and the last minute I tried power, and the car had already shut off,so I braced for the impact. The last thing I saw was armco, but have rubber marks on car. Please tell me what happened. Car was not hurt bad, should be ready for nasa race at vir by end of the month
Thanx, Larry
Old 07-03-2007, 10:21 PM
GreyGT-C
GreyGT-C's Avatar
pm sent!
Old 07-03-2007, 11:01 PM
the blur
the blur's Avatar
did you have the active handling on ??
Old 07-04-2007, 06:10 AM
rushon
rushon's Avatar
not on
To Offroading...
Old 07-05-2007, 10:34 AM
sothpaw2
sothpaw2's Avatar
Originally Posted by rushon
I am the driver that hit the tires/armco. I lost control under power in 3rd gear. Please tell me what happened.
Thanx, Larry
Larry, I'm a beginner but I imagine that you overcooked turn 3 and maybe the car was a little unsettled and your throttle input (which might not have been smooth) caused the spin. You'll have to elaborate on "under power", but throttle input is not something I associate with my memories of turns 3 & 4, steering is.
I remember turns 3 and 4 as both misleadingly (my instinct and eyes kept pushing me to early apex) late apex corners. I had less trouble with 3 as I learned to track out and hit the brakes late and turn late (later then my gut was telling me). With turn 4, I early apexed a little almost every time, and this upset the car a little (just the steering, no extra gas). You really don't need to be on it much here; this is a lot of steering to do and a lot to getting the car to the right part of the apex.
As my instuctor emphasized, if you aren't smooth with the throttle, the downshifts, and the braking (but the first 2 were my larger trouble spots) you will spin your car at VIR if you do those non-smooth inputs in the wrong places. I knew not to lift suddenly or gas suddenly in turns 3-4, there's no downshift there, and of course you brake before the turn, so that's why I never went off.
I'll be working on smoothness of a lot of stuff before I do another DE.
Old 07-05-2007, 10:39 AM
AU N EGL
AU N EGL's Avatar
When in doubt LATE apex with a corvette.
Old 07-05-2007, 01:04 PM
94ZR1#444
94ZR1#444's Avatar
Thanx, Larry
Larry,
Maybe you were thinking about this when you went off in T4: (This road is just before the entrance to VIR)
This looks like it was taken just after you stopped:
Armco? You were a few feet away from the Armco. I only see walls of tires. Bugeater will tell you how much Armco is to replace after we took out 3 uprights and moved the wall back about 9'.
See ya at VIR for NASA...
Mark
Quick Reply: Offroading...
