Trailer Help
Old 06-22-2008, 07:10 PM
Dave concrete
Dave concrete's Avatar
Default Trailer Help
Looking to buy a enclosed trailer so before any mistakes are made what do I need ,your suggestions are very helpful.
Old 06-22-2008, 07:17 PM
AU N EGL
AU N EGL's Avatar
minimum of a 24' with twin 5000 lb axles. brakes on each axle
Get a race hauler package not just a trailer with sides and a top
Pace America
Haulmark
are a few great names
Old 06-22-2008, 07:52 PM
JDIllon
JDIllon's Avatar
Pace America
Haulmark
Also, what are you towing it with??? That will determine a lot as to what you can buy!!! JD
Old 06-22-2008, 07:55 PM
Dave concrete
I have a F-250 SD DIESEL.Not mutch will be a problem.
Old 06-22-2008, 09:28 PM
Falcon
Falcon's Avatar
Pace America
Haulmark
Get one with a 48" side door.
Old 06-22-2008, 09:29 PM
Z07coupe
Z07coupe's Avatar
Look at Trailex.
Old 06-22-2008, 09:40 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
go as light as possible (ie Aluminum if you have the funds), and get axles and tires rates as high as possible. Just because you can FIT everything you own into a trailer does NOT MEAN the tires/axles can carry it......trust me on this one!
And if you don't have one, get a weight distributing hitch (even if you have a dually)
Old 06-23-2008, 01:12 AM
FastZR1
FastZR1's Avatar
I have an '04 F-250 6.0L and I tow a 28' Pace with no problem. I got the GT package with all the upgrades and found a good deal off www.racingjunk.com. I do recommend a good weight distribution/sway control setup (www.equalizer.com). I also put some Firestone airbags and gauges in my truck to help things out. Everything else is stock.
Good luck with your search.
Old 06-23-2008, 01:34 AM
Solo2GS
Solo2GS's Avatar
St. Jude Donor '07
Make sure it is a dove tail (rear end slopes downward). As it is with extra ramp extensions its a bit of a trick not to take the nose off when getting in and out!
I have a 24' Carson Racer Deluxe.
Can't seem to find a good picture of my trailer, but here is one from Carson's website to see dovetail.
You will likely have to add additional tie down points since most that come with the trailers are too far outward from the car.
Call around on pricing. 5 different dealers with the same trailer will come up with 5 different prices!
I would search used. You can get one all decked out for the price of a new hollow shell...
Old 06-23-2008, 02:00 AM
rustyguns
rustyguns's Avatar
me too 20k tow weight limit
Old 06-23-2008, 02:24 AM
Short-Throw
Short-Throw's Avatar
Are you researching a TAG or a Gooseneck?
I agree that the minimum should be 24".
E-track in the floor and walls will make life easier.
External lights and a 35 amp service is nice. Look into also having 12V lighting for quick 30 seconds visits inside at night.
I added an optional foot in height on mine and it was well worth it.
A transition plate is nice to have as it allows smooth rolling between the door and the trailer floor. A proper measured piece of wood can suffice if you want to be creative.
What kind of car are you hauling, does it require a winch?
Do you want roof access, if so you need to reinforce it so it can hold weight.
For a few dollars you can have it wired for A/C should you ever want to add a unit in the roof.
Will you have a generator, if so consider a side compartment to house it.
Like adding mods to a car, the list can sometimes be endless.
What is your budget? You'd be surprised how many things you can install.
Don't ask me how I know.
If you buy a toter home and stacker you can save money on lodging.
Mike
Old 06-23-2008, 06:41 AM
AU N EGL
AU N EGL's Avatar
Race junk dot come has many listed
http://nasa.racingjunk.com/
Old 06-23-2008, 07:45 AM
Feffman
Feffman's Avatar
minimum of a 24' with twin 5000 lb axles. brakes on each axle. Get a race hauler package not just a trailer with sides and a top
I'd suggest the torsion suspension as well. Towes a bit nicer then leaf spring suspension. If you don't have to have a new one, great bargains in secondary market.
Feff
To Trailer Help
Quick Reply: Trailer Help
