Where can I get 5000lb straps with snap-rings?
CI 3-5-6-7-8 Veteran
After todays incident I want straps with snap rings stat... my local trailer supply store doesnt carry them which is why I didnt buy them the first go around. Any help would be appreciated.
~Brian
~Brian
http://www.awdirect.com/?affiliateNum=411
That's where I get all my trailer/towing stuff... If it's good enough for tow truck companies, it's good enough for me!
Mike
Mike
Ratchet straps have a "Working Load Limit" or WLL of 1/3 the rated capacity. That means the 5,000 lb straps will safely hold just over 1600 lbs each.
Get the 10,000 lb straps; they will have a 3,300 lb WLL and they have the same hardware and the straps will be the same 2" wide. The cost of these straps are only a few dollars more than the 5K straps.
Looks like the link you show are the 10K straps
Howard Hill Enterprises, Inc.
5338 Jeffersonville Rd,
Dry Branch, GA.
(478) 743-8406
Ask for David
I got mine locally. He can custom make straps to any configuration as well. $80 for a set of four. These are 10,000lb straps that are 2" wide and 8' long with a flat snap hook on the strap and a twisty snap hook on the ratchet end. You can have David put the T-hook on the strap, but I would just buy them seperately if you don't already have them.
Here are a few pictures:
One other tip I learned on straps is to Knot the free end, I watched a car roll off a trailer as the entire strap freewheeled thru and completely out of the ratchet....the car stopped when it hit a tree...ouch
Not trying to high jack your thread, but I just picked up an 04 Z06 and already have atrailer that I trailered the C4 on, do I need the "T" hooks to strap it down correctly? Didn't need anything for the C4, straps just went right into the factory tie down "hooks". The straps I have have this type of hook on them:
CI 2-3-4-5-6-7-8-9-10 Vet
CI-X Auto-X Champ (street tires)
Cruise-In IX AutoX Winner
I am using these straps. http://www.uscargocontrol.com/2x12au...oks-p-240.html
2" X12' Auto Tie Down W/ Flat Snap Hooks, B.S. - 6,600 Lbs, W.L.L. - 2,200 Lbs
For a special order, they will do a twist on one end and a flat on the other.
If you use chains and the car it not perfectly straight one chain will not be as tight as the other.
North American cargo securement
http://www.fmcsa.dot.gov/safety-secu...nual-chap1.htm
Received 8,928 Likes
Bill
Platinum Supporting Vendor
You can get them at Mid Atlantic trailer next door to us. They always have them in stock thank goodness because we have lost our fair share of them. Anyways I don't use the T-Hooks, I tie directly to the control arm and this way the car will not move at all, the t-hooks work just as well and will load the suspension which is not going a long way is fine, I just choose the other way. Use 10,000lbs straps and use two on each end. I cross mine in the rear. Look up Scott Hudson, he will show you his rig and he will show you how to tie them down. Make sure you put the car in gear, you will not hurt anything.
