View Poll Results: When to change?
Voters: 40. You may not vote on this poll
Change the oil after 1 HPDE weekend?????
I ran 6 sessions a few weeks ago at CMP with NASA. M1 15-50 oil was changed the day before that and has zero street miles in it. Oil temps were between 270*-280* at the track.
I'm going to Roebling this weekend for 2 days and Road Atlanta the following weekend. My plan was to run Roebling and change it before RA.
Change it today or not?
My oil temp is much lower, 230° max and I change it once a year with running a few track events. With your higher oil temp I would run Roebling then change it since it will have seen several days of high temps, which can lead to break down.
Former Vendor
I for one would change the oil as often as you can afford. The oil is fine, but it's a good look at what is in the oil. You can save money in the long run, by screening your oil. We like to use paint filters.
Randy
Randy
Joe
When I change my oil I reset the DIC, 100%
after one hard weekend the DIC goes down to 70%
after second weekend down to 32-35% then I change the oil and send a sample to Blackstone and a local lab here in NC
Both labs say the change is about right.
I change my oil every 4-6 track days depending on the track run and track time at the event. The DIC usually reads between 45-50% at this time. OIL IS CHEAP - NEW LSX motors are NOT !!!
Thanks guys. I'll hold off for one more weekend. I'm installing an oil cooler anyway next week so the timing will be perfect.
How does one find a lab that will do an oil analysis?
I agree with Joe here.
OP: http://www.blackstone-labs.com/
http://store.summitracing.com/partde...5&autoview=sku
I decided to mount it to the condensor. I have it mounted, but not plumbed in yet because I'm waiting on the oil adapter block from LPE. I'm a little concerned that it may actually be too big. And no the bolts are not going through the condensor.
Can you post info on those labs? I want to send mine out and see how 282F treated it. How big of a sample do they need--do you just put the sample in an old qt container that only held new oil at one time?
Aren't you disagreeing with joe? Your data bascially says that the DIC isn't far off at all.
tests came back it was time to change the oil.
Maybe I should have said get your oil tested and just watch what YOUR DIC says. Not all will be the same Reading for oil percentage.
I stated tracking my car when there was less then 2500 miles on the Odometer. and that was also two oil changes.
I did two events with 5-w30, then had the oil cooler, accusump combo put on and then 15-w50 from then on.
24,000 miles on the clock with 20 some thousand on the track.
None of my oil samples are digitized but I can get some of the info and type it up
Call or go to there web site, posted above. and Get THEIR sample bottle and mailer. prior to your oil change.
You want to get the sample as it comes out of the crank case.
Thanks for the pics Sperkins. From what I got out of the other thread, that is the only place to put it. Do you have the stock radiator? I have a DeWitts ready to go in as soon as I get a chance. Surely that will add enough cooling to offset oil cooler. Did you look at the B&M oil cooler kits before getting yours?
I'm a little when it comes to this stuff but I change my oil before every event, and the driveline fluids every other event.
analysis from Blackstone labs shows my 92k mile turbo charged 4cylinder is holding up excellent to the abuse so far, and so is the driveline, shifts as good if not better then when it was brand new.
still have the same 15w-50 oil in the vette from when I did pocono on 7/20 but you can bet that will go to blackstone for analysis too.
