Safe to run directional tires backwards?
I use Nitto NT-05s at HPDEs. Most of the tracks I go to are a clockwise configuration so all the right hand turns really chew up the left tires. So, I want to run the right wheel on the left side and vice versa to equalize tread wear. Is it safe to run these tires backwards? I know I can go to the tire shop and have them swap the left and right but then that gives them a chance to scuff up my wheels
Isn't the directionality only applicable to water evacuation? Ok to run them backwards on a dry track?
I've run several different brands backwards on DRY road courses.
Have to make sure they are running the correct direction if it gets wet.
i happened to see the formula 1 slicks recently. they are directional ... yes directional SLICKS. so at least for those tires, the directionality is not about water evacuation.
certainly it's *safe*. you may be compromising performance.
with all the above posts, but I want to add one more comment.
The reason I get my tires swapped from left wheel to right wheel is not to balance the wear tire-to-tire. It's to balance the wear outer tread blocks versus inner tread blocks. With my suspension compliance and camber settings, I'm still wearing the outer side of the tires faster than the inner side. It's a compromise I'm willing to accept for my daily driver & weekend track car.
I've found that I can get another track day or two from a set of tires if they get a left-to-right dismount & remount about halfway through their life.
