Is an accusump worth the investment?
Over the weekend I added this post to a thread entitled "Clearly LS3s make for horrible race motors"... had not heard much back so will start my own thread:
In order to get better oil lubrication on my LS3 for the track, I am considering installing an accusump. I realize most trackers put in a good dry sump, but I don't have the money to go that way. I am hoping to hear from anyone out there that has installed an accusump.
So far the only changes I have made to my '08 is to put on Pfadt street sway bars and I added a Z06 oil cooler. Plus each time before I head to the track, I change out wheels/tires & brake pads. I have been enjoying tracking my M F55 six to eight days a year in HPDE 4 and so far have only gotten away from run-flats by changing to Falcan 452's but hope to have something like Toyo 888's by next mid season.
So.... does installing the battery in the trunk and putting a 2 or 3 quart accusump make real sense for better lubrication on the corners of Thunderhill and Infineon?
Wish I could help you specifically about the LS3, but all I can add is that my raceshop feels its a very worthwhile investment on LSx motors due to their oiling issues.
Also, do you need to relocate the battery? On the C5's we tuck them in the inner front fenders.
It's a waste of time and money on an LS3 though guys...it does nothing...and will NOT keep it from blowing up...will NOT help with the oil temps...and will NOT help with the puking issue.
If you don't believe me, go back and watch the 2008 Runoffs at HPT - specifically Mike Tracy's LS3 go kaboom on lap 14. He had the GM optional pan and an accusump and none of it helped. It went up like a comet. Others have tried as well...
What about a accusump on a full blown 442ci LS7? My builder is looking more at doing accusump plus a nice baffled oil pan like that Miloden that was posted a few weeks ago. He has a World Challenge car and has had many issues with the dry sump system in that car and thinks a proper wet sump system with the accusump and baffled pan would be just as good and have less maintenance problems. I am building the car to run the Cannonball Run and the simpler and less potential for problems the better I will be off. For the Cannonball it will be on street tires but for normal track days it will be on non-DOT R-compounds. I have a 3 way adjustable Moton suspension for it and there will be a bunch of Pfadt stuff added as well...so G-force should be a decent amount in corners. Also Aero will be added with a 72" rear wing and 4" splitter.
Anyone have any thoughts on this? I and my builder want to keep it as problem free for the Cannonball as we can as that is one of the keys to success on a race like that.
CF Senior Member
I feel an Accusump is worthwhile especially if you use sticky tires and run tracks with extended banked curves. There are never any guarantees...I've known guys with dry sumps that have trashed their engines due to oil starvation. The way I look at it...for the price of an Accusump and the potential benefit of saving a rather expensive built engine an Accusump is cheap insurance.
This would be an interesting comparison data point to the known-to-be-100%-effective dry sump parts / install cost at $7-8k.
St. Jude Donor '03
We had a lot of problems using an accusump on a wet-sump motorcycle engined car. The solenoid was causing electrical interference issues and it didn't work all that well.
We had a one quart accusump, but it definitely could not maintain pressure through hard braking zones(2.9 g's). The best available solution was a different pickup and better baffling while waiting for a good dry sump system.
They also put on an oil cooler and trans cooler system at that time.
Plus some other small things.
So price I dont really remember, but they were the only place at the time that knew HOW to do the install. Other shops said, "Yah we can to that. We can FIGURE IT OUT"
so that and Phoenix's reputation, done deal
I can't speak for the LSX cars, but on my LT4 I was getting wicked low oil pressures in high G turns. The pressure was low enough to turn on the big dummy pressure warning light on a regular basis (12 psi). I put in a 3 qt Moroso sump and no more light. The pressure stays at or above 45-50 psi (hot) now which is obviously a HUGE improvement.
I have a manual valve and forgot to open it once not long ago. In the first corner watched the pressure drop and knew exactly what I did. Like I said, I have no idea about the LS cars, but it has made a huge difference in keeping pressures where they should be on the LT.
I have 2 1/2 seasons on a stock short block w/out any issues. I do run a Canton pan but that's it. It's not worth the price when my short block only cost $890.
