Clutch fluid vs. brake fluid, and remote reservoirs
Old 09-11-2010, 05:28 PM
Everett Ogilvie
Everett Ogilvie's Avatar
Default Clutch fluid vs. brake fluid, and remote reservoirs
My car has Tilton pedals and master cylinders. There is currently one remote reservoir that feeds the 3 master cylinders. I am going to be installing Gary's new T1 brakes and I will be using Castrol SRF brake fluid, and I am wondering whether I need that quality of fluid for the clutch.
I am considering buying the Tilton 3 chamber remote reservoir to put in place of the single unit on the car now. If I do that I can use the SRF in the 2 brake chambers, and I could choose any fluid for the clutch. I will certainly stick with DOT 4 fluid for the clutch, but maybe the clutch fluid does not need to be quite as good/expensive as the SRF that will be used in the brakes? To date I have never had any heat issues with the clutch fluid but I appreciate the need to use quality fluids throughout.
Thoughts? Any and all inputs are appreciated!
Old 09-11-2010, 05:38 PM
trackboss
trackboss's Avatar
What you are planning on doing is ok. I have triple m/c's on my race car, but have always used the same fluid simply because I had it and it was not expensive SRF. On many race cars you will notice one of the three reservoirs has a differnent color fluid and it is because of what you mentioned above.
Old 09-11-2010, 09:01 PM
flink
flink's Avatar
Lots of people have lots of problems with the clutch hydraulics: http://www.google.com/#q=corvette+cl...ticks+to+floor
The clutch takes very little fluid. Put the good stuff in there.
Old 09-11-2010, 09:16 PM
63Corvette
63Corvette's Avatar
I concur! Use SRF or RBF 600 in all hydraulic applications
To Clutch fluid vs. brake fluid, and remote reservoirs
Quick Reply: Clutch fluid vs. brake fluid, and remote reservoirs
