Fluids for the track car..... what do you use?
Old 11-11-2010, 09:48 PM
Gman57
Gman57's Avatar
Default Fluids for the track car..... what do you use?
As I'm setting up my C6Z as a track only car all the fluids that would otherwise worked on the street more than likely should be changed out. What do you use and why (brand,weight,compound etc)? What are the recommended change intervals on the different fluids with a track only set-up. Do you go by hours,miles,events,what?
Thanks in advance for your input
Old 11-12-2010, 07:25 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Amsoil
I change the oil by the life monitor, the trans and diff before every season. But I run TT so we don't see a lot of laps, but the laps we do run are........flat out.
Old 11-12-2010, 07:48 AM
Brent Dalton
Brent Dalton's Avatar
Because that's how Jason drives... flat. out.
I also second the use of Amsoil. Switched over at the beginning of this season.
Old 11-12-2010, 08:07 AM
Bills Z06
Bills Z06's Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Amsoil for me!
Old 11-12-2010, 09:09 AM
Gman57
Gman57's Avatar
I have a friend that is getting set up as a Amsoil dealer so this is good to hear
What actual Amsoil fluids would you use in your Z (LS7)?
Old 11-12-2010, 09:22 AM
Brent Dalton
For track use, I run 15w50 for the engine, synchromesh for the tranny, don't remember for the rearend but I think it's 75w140 or 110. I know that's what Jerry Onks runs as well when he is racing his STO C6Z.
Old 11-12-2010, 09:27 AM
CHJ In Virginia
CHJ In Virginia's Avatar
I use all Mobil 1 synthetic fluids in my 03 Z06. M1 synthetic ATF in tranny, M1 75-90 Gear lube with the GM posi additive just in case, synthetic power steering fluid and M1 5-30 for the engine. Change out trans, diff and PS on an annual basis and engine oil every third event or when DIC hits 50%, usually every third event. Been tracking for over 5 years with almost 10K track miles and knock on wood no problems yet.
Old 11-12-2010, 12:21 PM
froggy47
froggy47's Avatar
Redline
Old 11-12-2010, 12:59 PM
4wheels
4wheels's Avatar
Diff: Amsoil 75-110 Severe Gear
Trans: tried several, they all have drawbacks but Redline D4 works well for many, but is a bit thin at high temps for me
Engine: Renewable Lubricants Inc (RLI) 5w-40 HD. Stands up to more track events & gives me lower wear readings than anything else I've tried.
Old 11-12-2010, 01:04 PM
63Corvette
63Corvette's Avatar
Brake fluid is the one you need to worry about. I recommend Castrol SRF!
Old 11-12-2010, 01:57 PM
Gman57
Gman57's Avatar
I've been using Motul RBF 600 for my C6 Vert when tracking it with no fade issues. Keep in mind the with the vert I'm only running hi-speed 15-20 min. at a time with 30-40 min cool down time between
What makes the Castrol SRF better... do you get more use time between changes or longer track times with out fade issues?
G
Old 11-12-2010, 02:40 PM
dfinke23
Support Corvetteforum!
dfinke23's Avatar
G
I have spent less money with SRF than anything I else I have used. I do a flush before the first event of the year and bleed once around the midpoint of the season.
Old 11-12-2010, 02:55 PM
TS Motorsport
TS Motorsport's Avatar
I run amsoil fluids in my diff, trans, and clutch. I run german castrol in the engine but will soon switch to amsoil. I run motul 660 brake fluid which I'll soon replace with castrol.
Old 11-12-2010, 04:26 PM
rfn026
rfn026's Avatar
All Amsoil and Wilwood brake fluid.
Richard Newton
Facebook
Old 11-12-2010, 05:02 PM
4wheels
4wheels's Avatar
G
The Motul is more hygroscopic and will therefore need more frequent changing. The single advanced feature of Castrol SRF is the way it handles moisture. Not only is the dry boiling point high, but the fluid is less hygroscopic, and what water is does absorb is trapped so it doesn't boil off or rust your braking system, so it can be left in all season offsetting the initial cost (and thus also has a very high wet boiling point).
For clutch, I use Amsoil 600 since it needs to be changed every event to get rid of the clutch dust in the fluid and it has a very high dry boiling point.
Old 11-12-2010, 06:40 PM
RichieRichZ06
Supporting Vendor
RichieRichZ06's Avatar
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes on 597 Posts
St. Jude Donor '08
I am an AMSOIL dealer so if anybody needs anything let me know. It would be supporting a fellow Corvette owner, gear head and racer. If ordering online feel free to use referral # 1855896
Old 11-12-2010, 07:29 PM
0Anthony @ LGMotorsports
Former Vendor
Anthony @ LGMotorsports's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
RedLine 40W race oil in the engine
RedLine D4 ATF in the tranny, extreme duty cars I'll mix in one quart of MTL
RedLine 75w90 Diff oil
Castrol SRF brake fluid
If you do dual use with the car, I would run Mobile 1 or RedLine street oil through the engine during off season use to keep the inside clean.
To Fluids for the track car..... what do you use?
Old 11-13-2010, 01:44 AM
TheSkunkWorks
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
Originally Posted by 4wheels
The Motul is more hygroscopic and will therefore need more frequent changing. The single advanced feature of Castrol SRF is the way it handles moisture. Not only is the dry boiling point high, but the fluid is less hygroscopic, and what water is does absorb is trapped so it doesn't boil off or rust your braking system, so it can be left in all season offsetting the initial cost (and thus also has a very high wet boiling point)...
Good explanation. Given the above together with 518* wet / 590* dry boiling points of the Castrol SRF, there's plenty argument for absorbing the initial expense. Compatible with conventional fluids too, so you don't have to do an absolute purge to begin using it.
BTW, where's the best deal on it (not in bulk quantities) you guys have found?
Old 11-13-2010, 07:28 AM
AU N EGL
AU N EGL's Avatar
castrol may be more per bottle, but you will spend less over the season.
Castrol SRF
M1 15-w50
M1 Gear Oil
M1 ATF
water and two bottles of water wetter in radiator
Old 11-13-2010, 10:47 AM
C5ZEE06
C5ZEE06's Avatar
my Redline supplier recently recommended the Redline D6 ATF (Dex VI) vs the D4 (Dex III ?) for my C5 M6...hope thats OK..
Quick Reply: Fluids for the track car..... what do you use?
