Torx size for rear wheel bearing bolts.
Mine were torqued in really tight.
Had to use the pneumatic impact wrench at full 90 psig at full 300 ft lbs torque to get at least 3 of them out (did both spindles in the back).
The really tough ones were recessed into the spindle.
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Yep T-55...I keep a couple spares as they break from time to time.
They have lock-tite on them, use a little bit of heat on the bolts and they come out pretty easy. Make sure they go back in with lock-tite on them and I generaly re-check them after the first drive cycle just to be sure.
