No Corvettes in Rolex 24 at Daytona
Old 01-20-2011, 01:55 PM
CDN_Wolf_eh
CDN_Wolf_eh's Avatar
Default No Corvettes in Rolex 24 at Daytona
I haven't been a huge fan of the Rolex Grand-Am series ... but last year with Lou running his Vette in the series, I tuned in for a few of the races.
I just went to the 24 Hours of Daytona site, and looked at the Car/Driver line up ... NOT ONE TEAM RUNNING A CORVETTE!
Seems like most teams are running Maxda's / Por-Shaaa's and Camaro's ... what the heck is going on????
Lou or Louis, chime in and let us know whats happening!
Mark
Old 01-20-2011, 01:58 PM
AU N EGL
AU N EGL's Avatar
it appears that GMs push in Grand Am is the Camaro
There should be a corvette or two in races after the 24 hour.
th costs to race in Daytona are almost out of reach for smaller privateer teams
Old 01-20-2011, 02:26 PM
shakedown067
shakedown067's Avatar
St. Jude Donor '12-'13
Old 01-20-2011, 08:52 PM
BrianCunningham
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
I still remember they year they won...OVERALL
Old 01-20-2011, 10:55 PM
Lawdogg
Lawdogg's Avatar
The one time I can honestly say I was there.
Old 01-21-2011, 05:08 PM
CDN_Wolf_eh
Too bad the costs are too high ... it's the premiere race of their series ... I would want to be there, no matter what, if I was a team sponsor!
Old 01-21-2011, 07:44 PM
redazz
redazz's Avatar
several familiar names in camaro's though
johnny o'connell driving the autohaus motorsports camaro
oliver gavin and eric curran in the banner racing camaro
jan magnusson in the stevenson motorsports camaro
should be fun to watch them race agains each other
john
Old 01-21-2011, 08:16 PM
TLGunman
TLGunman's Avatar
About half of the years budget will go into this one 24 Hour race.
Old 01-21-2011, 11:33 PM
Charleston2012
Charleston2012's Avatar
GM will go to Europe though and compete in LeMans.
Wont compete in the USA, sad.
Old 01-22-2011, 07:46 AM
AU N EGL
AU N EGL's Avatar
Yes and NO
Corvette is in the American LeMans Series and LeMans 24 hour which is run by the ACO
Grand Am is a different sanctioning body
GM has the Chevy LS6 engines in the Daytona Prototypes and the Camaro in the GT class
You will see the CHEVROLET banner on windshields of many DP cars.
Old 01-22-2011, 09:17 AM
Painrace
Support Corvetteforum!
Painrace's Avatar
It has always ben big $$ but today you can race for the rest of the year and spend about the same $$ unless you have a ig impact.
Jim
Old 01-22-2011, 09:27 AM
jasonberkeley
jasonberkeley's Avatar
They are running factory backed Camaros in Grand-Am. Both in Rolex GT, and in Cotinental Challenge GS. Look at the driver line-up in the Rolex GT Camaros- GM factory drivers.
It's all about marketing. Corvette is all about technology and high-level image, which is what the ALMS and LeMans represent.
Grand-Am is a more low-tech series than the ALMS, and GM also wants to market the Camaro as a performance vehicle, so the Rolex GT and Continental Challenge series are the right place to race.
If they support another product other than the Camaro in the same series, they work against themselves and their ultimate goal of having the Camaro win the series championships.
Old 01-28-2012, 08:25 PM
Joezone914
Joezone914's Avatar
Yes and NO
I read the prototype has de-stroked 305CI motor with LS9 cylinder block with direct fuel injection making 530HP. Not sure what's in the camaro.
Old 01-28-2012, 08:31 PM
69427's Avatar
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Help out a guy with a lousy memory. What year was that?
Old 01-28-2012, 08:48 PM
acrace
acrace's Avatar
2001 - when the race was run under ALMS rules and not Grand Am.
Old 01-28-2012, 09:07 PM
acrace
acrace's Avatar
By the way, there was at least one Corvette in the GT class. #46. I *think* that it's already out.
Old 01-28-2012, 09:20 PM
JETninja
JETninja's Avatar
WA Events Coordinator
1 GT Class C6
4 DP Class Corvette's
To No Corvettes in Rolex 24 at Daytona
Old 01-28-2012, 09:26 PM
Han Solo
Han Solo's Avatar
Yes and NO
I thought the LS6 was history. I don't think they should be able to run an engine that you can't buy.
Old 01-28-2012, 09:27 PM
joemoia
joemoia's Avatar
Rolex DP rules allow LS7 or LS9 block casting
CHEVROLET* 5.0L V8
*Can also be branded as Cadillac. Engine block Casting # 12598723 or 12621766 with specified bore: 3.900″ Stroke: 3.185″ Minimum crank weight: 38 lb Maximum compression ratio: 11.5:1 Cylinder heads part # 17802752. Intake and exhaust ports cannot be modified. Cylinder head intake runner maximum volume: 230 cc’s Cylinder head exhaust runner maximum volume: 87 cc’s Intake valve: 2.100″ Exhaust valve: 1.550″ Piston w/rings, pin and connecting rod: 1000 gm minimum. May use titanium wrist pin. Maximum camshaft lift @ retainer with zero lash: .590″. Maximum cam duration: 248°/251° @.050″ lift. Must use with no modifications. Maximum RPM: 6900 Maximum fuel pressure 5 bar ( 72.5 psi)Part # K-GMDPAA Intake Manifold, w/ 2.0 inch I.R. Kinsler Throttle Bodies. Inlet trumpets and air box as submitted and approved. Air box base Part # 17802737
For GT, 2012 rules specify LS3 with spec cam and LS6 throttle body
Old 01-28-2012, 10:37 PM
el es tu
el es tu's Avatar
6th picture down
http://forums.corvetteforum.com/auto...ona-today.html
Quick Reply: No Corvettes in Rolex 24 at Daytona
