Deglaze pads and rotors regularly? Yes/No? What about the transfer layer?
stock car teams use new pads and rotors for each day of racing.
and If I am not mistaken the glazing is from too much heat or ie using the wrong brake pad for that friction level. too soft of a brake pad
That's been my experience as well. The haze comes from severely overheating the pad and basically melting it. When that happened I used sandpaper and brake cleaner to "wet sand" the rotors and the pads.
When there is "glaze" on either the pad or the rotor then the "transfer layer" of good pad material has been compromised.
Sometimes I get a little glaze spotting and then a few hard stops shreds it off, but if it's bad, like those pads in the pictures then a cleaning like they are doing is smart & then you put down a fresh transfer layer.
The only thing I would add is use garnet paper, not alum oxide or emory.
