carbon ceramic rotors
Old 08-03-2012, 11:42 AM
fatbillybob
fatbillybob's Avatar
Default carbon ceramic rotors
Any comments from users on the plusses of the ZR1 carbon ceramic brakes for track dudty?
Old 08-03-2012, 01:29 PM
RX-Ben
RX-Ben's Avatar
Are any race pads available for these?
It looks like a relatively inexpensive upgrade, depending on how the rotors hold up.
Old 08-03-2012, 02:51 PM
AU N EGL
AU N EGL's Avatar
rotors and pads are from Hitco or Brembo/Honeywell.
Most ppl do seem to like them very much.
Old 08-03-2012, 04:05 PM
fatbillybob
Yeah...rotors are like 1300 and calipers like 400! On a Ferrari they make so few that $20k with labor is a complete R&R pads, rotors, fluids. Corvette economy of scale makes those numbers fall like a rock.
Old 08-03-2012, 04:09 PM
RX-Ben
RX-Ben's Avatar
Everything Ferrari has an extra "0" added on to the price.
Old 08-03-2012, 04:11 PM
NOSLO6
Support Corvetteforum!
NOSLO6's Avatar
Spring Mountain runs ZR1s don't they? The student cars probably don't see hard use, but they do see lots of track miles.
The folks there are always helpful and it would be one point of information.
Old 08-03-2012, 04:47 PM
topmover
topmover's Avatar
As with anything else different people will have different opinions and different results. I have a modded C5z with Big AP's on the front and C6's on the back running Cobalt XP1's. I also have a ZR1. The set up on my C5 seems to have as much(if not more) stopping power however it is much more touchy/violent than the ZR1's brakes.
I just put my(original plus 2) 3rd set of front rotors on my ZR and will put my 2nd set of rears this weekend. In round numbers the fronts rotors are lasting 10 track days and the rears 20. The pads are currently lasting about 2-2.5 track days on the front and about 4 for the rear.
If cost isnt a major factor the biggest issue with the ZR1 brakes is you must do the street brandish for them to work right. This is a major PIA since the timing of needing pads doesnt always line up with ones track schedule.
My C5's brakes feel like a old Mack truck compared to the ZR1's.
Old 08-03-2012, 05:21 PM
Lasco001
Lasco001's Avatar
This is my brake in the C5 Race Car
I use this in the Z06 and ZR1 in the
Brembo Race Brake 380x35
Pad Pagid RS15 and Carbotech XP12
Old 08-03-2012, 06:11 PM
Adam@Amp'dAutosport.com
Supporting Vendor
Adam@Amp'dAutosport.com's Avatar
St. Jude Donor '11,'13
Carbotech does make pads for the ZR1 ceramic rotor. I will be happy to help you.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old 08-03-2012, 06:22 PM
Lasco001
Lasco001's Avatar
Default Ceramic Brake
I've been yet.
I have for all models of Corvettes from Carbodech blocks for storage
Also for my racing brakes which I verbaue in the ZR1 I Cabotech pads
Old 08-03-2012, 06:59 PM
Werks
Werks's Avatar
Adam, can you give us some info on the pads that Carbotech has available for the CC rotors?
Old 08-04-2012, 10:54 AM
Supporting Vendor
We are using the same pads as we use on the steel rotor, so you can use any of the compounds we make. Jason at Katech was the first to test these he did have a problem with the street pad but I think we have worked through that. Than he just tested a set of XP10 with great results hopefully he will chime in. Below is a message he left me.
All good buddy. After the first session they wiped away the glazing on the rotor and I had more brake than tire. No brake fade at all. If anything a little tire fade as they got greasy. I wish I had a set of full slicks so I could put them to the test.
Old 08-04-2012, 02:20 PM
Werks
Werks's Avatar
Yep I know that Jason was running them as we spoke about them briefly while at Track Attack. So if I'm not mistaken the XP10 are the pads that the Ferrari guys are running on their CC brakes also? Do you have any data on longevity of pad life and rotors with them?
Old 08-04-2012, 03:34 PM
Katech_Zach
Premium Supporting Vendor
Katech_Zach's Avatar
C7 of Year Finalist (track prepared) 2019
I glazed my first set of street pads during the rotor burnishing process. Adam got me some XP10s and I took those to Track Attack. As they started to bed in they came in nicely and gave me more brakes than my cup tires could handle. It would be really nice to see what they're like with some Hoosiers. I haven't heard a peep out of them driving around the paddock or on the street when I got back. So far no squeaking even though they are a track pad.
__________________
Contact:
(e) zach@katechengines.com
Old 08-04-2012, 09:10 PM
whatcop?
whatcop?'s Avatar
Location: Daytona Beach/ Atlanta---- Good Ol' Florida Boy/ Georgia
I did 2 days at road atlanta last weekend in my ZR1 and the brakes preformed flawlessly. I am running Castrol SRF in the system and before I head out next time I'll install the brake cooling ducts just for extra insurance.
To carbon ceramic rotors
Quick Reply: carbon ceramic rotors
