Active handling defeated!
#103
You lose Competitive Driving Mode (think newer driver and rain), and you will likely not have TPMS depending on the method you use to disable it. TPMS COULD help if you had a tire going down or had no idea where to set your tires. An advanced driver can tell to a high degree what each tire is doing pressure wise and can sense if there is a problem.. again something a novice could benefit from. I'm not arguing for it, just saying those are the likely counterpoints.
#107
I'm only asking because I've had mine unplugged for a month now and have noticed no adverse effects what-so-ever. I have yet to track the car w/the plug out, but the appeal of not having to worry about TPMS or AH killing a weekend outweighs all other points against this.
It would be a big no for people with mag ride, but I'm not that fancy.
HC Mechanic (01-28-2018)
#108
I just had my tpms act up this with the DIC morning telling me I had a flat and 6 psi in a tire that clearly was inflated... after I parked the car to check it out the error went away. I never use AH and am considering disconnecting the sensor; has anyone had any problems with this? Will it screw up my steering wheel position (have the telescoping wheel on my c6).
Also does this allow the use of tc? I rarely use it but it would be cool to have some TC available if needed while still killing the AH.
Thanks!
Thanks!
#109
Thanks!
Thanks!
IE rutted highway in rain
#110
I've had zero issues, ever. Not even a single close call or butt puckering moment. If you use a shred of common sense, you'll be fine. Especially if you use normal street tires. I've considered never even hooking it back up as it seems just plain unnecessary.
#111
question
other than not being able to read tire pressures why is it bad not to have TPMS in your wheels ( track or street )?
i have 2 sets of wheels for my 06Z06, 1 set has working TMPS and the other set has TMPS but not programmed to the car so the DIX reads xx xx xx xx on all for tires
i get no codes of yellow warning lights at all and can still cycle thru active handling modes
i have tested and my Traction control and Active Handling works ( trying to do a burn out, donuts, aggressive corners and getting off steep/angled driveways ) so i know my A/H T/C works as intended
can some1 explain me why is it "DANGEROUS" to drive with bad or missing TMPS?
#112
question
I found tpms to be of limited value until last month's Laguna track day where I discovered a slow leak after lunch. I pumped the tire up and crossed my fingers as I drove two hours back home. It turned out to be a loose stem nut, but once I figured out how to reliably reprogram the tpms, it's not a big deal.
#113
Normally if the car detects none or malfunctioning tpms it goes into limp mode, which imposes high or max levels of AH/TC and limits speed by cutting engine power (ignition?). I've had it happen on track and the car was alternately a handful and then really slow and non responsive......I felt I had limited control of the car, not good on track. On the other hand, I have driven home with non functioning tpms and it seemed to be ok; it allowed me to drive at 75mph, which puzzled me since I assumed the car was limited to 55 when in limp mode.
#114
This works on a C5 Z as well. I was having issues with the car going into "reduced engine power"/ "Service Active Handling" during autocross runs. It would do it at least once per event. After finding this thread, I unplugged the steering angle sensor before going to a track weekend, and it's perfect. No issues whatsoever. I don't use Competetive Drving Mode so no loss there.
This is at the base of the column closest to firewall. You don't need to take any part of the dash or under steering wheel plastics. It looks similar to the C6 pics on page 1 of this thread except it's a light green color on the C5.
#115
Thanks!
Thanks!
#116
The other magical question....
Does this defeat Dynamic Rear Brake Proportioning on my 2004 ZO6?
If I brake while turning it feels like the ABS is rattling my pedal and I am almost positive it is not regular pad knockback...
I have a feeling Dynamic Rear Brakes is stuck in the ECBM....
#117
#118
got a question im looking for clarification on.
if i disconnect the SWPS plug under the column, and my track wheels DO have TPMS in them. does the TPMS work correctly? ie are Psi still displayed on dash?
or does disconnecting the plug also cut the communication coming from the TPMS? ie no Psi readouts on dash? what does it display? XX?
#119
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
#120
My last track session the active handling did kick in with the SWS disconnected! I couldn't go over 35 on a corner
I broke down & got a track box from LG, nothing like losing a whole day at VIR
