Track tire question
Old 12-22-2012, 10:44 PM
Toilets
Toilets's Avatar
Default Track tire question
I want to switch it up this season and go from Hoosiers r6 to Michelin cup tires.
They will be the same sizes (295/30/18 and 345/30/19) but the problem is the michelins have a diameter delta from front to rear of 2 inches. ( 25.2 front diameter and 27.2 rear diameter )
I still want to run stability control and abs etc. since I'm still learning. Having said this, is this diameter delta to big?
The Hoosiers were only 1.5 difference between the 2.
Old 12-23-2012, 03:02 AM
rustyguns
rustyguns's Avatar
If i remember correctly C5 allows a 3 percent difference. C6 possibly the same?
Old 12-23-2012, 07:48 AM
Poor-sha
Track Rat
Support Corvetteforum!
Poor-sha's Avatar
Received 3,405 Likes on 1,374 Posts
I ran that exact setup for a year on track with AH. No problems. 2008 C6Z
Old 12-23-2012, 08:17 AM
Toilets
Toilets's Avatar
Do you mean 3 inches?
Old 12-23-2012, 08:18 AM
Toilets
Toilets's Avatar
The Michelin set up?! This will be awesome news if so!
Old 12-23-2012, 02:06 PM
morris
morris's Avatar
I run sport cups on my C6Z 345 19 and 285 18 runs great no computer issues 295 should be even closer
Old 12-23-2012, 04:32 PM
Toilets
Toilets's Avatar
Thank you all! I just made the plunge and got them!
Old 01-04-2013, 11:39 AM
Toilets
Toilets's Avatar
Are you running the pilot sport cut tires?
I ask because I got the rear tires but now people are saying the diameter difference is to much and that I will have AH problems
Appearently the magic number is .942.
If you take the front diameter (25.2) and divide it by .942 then that will give you the maximum rear diameter you can have. Which in this case would be 26.8 after rounding. Anything over that and Appearently you will have all sorts of problems.
I really don't know what to do as I don't want to get stuck with tires that don't work. And these are the only tired with a tread wear under 100 that fit.
My first event this season is feb 9th so I don't have much time.
Old 01-04-2013, 01:40 PM
jamsvet
jamsvet's Avatar
Let me know how this works out. I'd like to see what performance dropoff you have vs the Hoosier. I wouldn't mind getting more than two weekends out of front tires.
To Track tire question
Quick Reply: Track tire question
