wiring cutoff switch, kill battery and?
Old 08-12-2013, 11:36 PM
moespeeds
moespeeds's Avatar
Default wiring cutoff switch, kill battery and?
Got a 4 post cutoff switch. I'll kill the battery and what else? Which ignition wire is the correct one? Should I keep the starter wire on the battery or should I run that through the cutoff switch as well? I'm running 2ga wire to the switch.
Old 08-13-2013, 03:28 PM
moespeeds
moespeeds's Avatar
Bueller?
Old 08-13-2013, 03:32 PM
moespeeds
moespeeds's Avatar
The threads I searched show guys cutting the alternator wire, but an experienced mechanic buddy is telling me this is bad for the alternator?
Old 08-13-2013, 03:34 PM
travisnd
travisnd's Avatar
There's one power wire to the main distribution block under the hood that will kill everything on a C5. Only one wire to splice into. I'll try and find pictures. I know a forum member who's an electrical engineer posted a good how-to with pictures awhile back.
Old 08-13-2013, 03:36 PM
travisnd
travisnd's Avatar
http://forums.corvetteforum.com/auto...lp-needed.html
See post 7
To wiring cutoff switch, kill battery and?
Quick Reply: wiring cutoff switch, kill battery and?
