What are the best rotors available for stock C5 brakes?
Old 10-21-2016, 12:47 PM
ponycar
ponycar's Avatar
One of our sponsors, KNS, sells the DBA rotors for great prices. Like many of our members I track my C5 quite a lot. The DBA rotors have outlasted the stock GM, made in Mexico, rotors by more than double, for me specifically. The rotors made in China have not lasted as well as the ones made in Mexico for my purposes. The stock rotors develop cracks much sooner than the DBAs, in my experience. I have been running one set of DBA rears all season. Stock tended to last about 3 weekends.
Old 10-21-2016, 02:32 PM
froggy47
froggy47's Avatar
Originally Posted by FASTFATBOY
Best I have found so far for the money is Centric high carbon, about $230 a set of 4 from Autoanything.com
Old 10-21-2016, 03:24 PM
Dan H.
Dan H.'s Avatar
St. Jude Donor '17
I'm on my first set of DBA rotors and will be going with these in the future instead of the centrics for the reasons mentioned above.
Old 10-22-2016, 10:36 AM
Scooter70
Scooter70's Avatar
The KNS DBA 4K rotors are the sweet spot for single piece rotors right now since the stock of Brembo XLR rotors dried up. They're just under $240 shipped for the whole car set.
https://www.knsbrakes.com/c/car-seri...-+Single+Rotor
If you're looking for two piece, Mark's rotors above are a work of art.
Old 10-23-2016, 08:03 AM
Mark@AMT Motorsport
Supporting Vendor
Mark@AMT Motorsport's Avatar
Old 12-22-2016, 09:08 AM
6998824's Avatar
Contrary to popular beliefs here are no Rotors made in the USA any longer, its either China or Great Briton, I went with the later EBC slotted and dimpled and have had no problems.I understand that their is a new foundry being built in Australia but haven't confirmed that.
Old 12-22-2016, 09:24 AM
FASTFATBOY
FASTFATBOY's Avatar
This year there was a foundry opened and running in the US, Brembo I think but don't remember.
But there is a brake rotor foundry in the US.
Old 12-22-2016, 07:36 PM
BTTBSS
BTTBSS's Avatar
Default Rotors
The DBA C5 rotor weighs 22lbs. Properly seasoned they last a long time. I ran them on a 4,350 pound whale for years and got a season or more out of each set.
Old 12-22-2016, 08:38 PM
FASTFATBOY
FASTFATBOY's Avatar
Which rotor? What do you constitute "a season"?
Old 12-22-2016, 10:34 PM
BTTBSS
BTTBSS's Avatar
Default Impala on C5 Brakes
In a year 8-10 track days. Typically 200 miles in a 3-day weekend at VIR. Two day event would rack up 120 to 150 miles. Plus about 2,000 miles a year street driving. XP-10 in front and XP-8 on rear. Rotors are DBA one piece rotors. Their stock replacement for a C5. I have them clocked and drilled 5 X 5 for the Impala.
Rebuild the brakes every winter so I can start with new pads and rotors and not have to work on the car at the track. Front rotors will have some small cracks when changed but could have been run longer. One thing that I believe helps is to drive around for 10 minutes or so after each track session and let the brakes cool down.
Old 12-22-2016, 11:25 PM
FASTFATBOY
FASTFATBOY's Avatar
One set of XP10 last you 8-10 days in that car? Or just the rotors?
Old 12-23-2016, 03:14 PM
BTTBSS
BTTBSS's Avatar
Yes one set of pads and rotors. You can run the Carbotech pads right down to the nubbins and I drive to save the brakes as much as possible.
Old 12-24-2016, 01:17 AM
  #33
kdm123
kdm123's Avatar
When you wear out the rotor on a two-piece rotor, can you send them back to the mfg to have a new rotor fitted to the hat?
Old 12-24-2016, 07:14 AM
  #34
rfn026
rfn026's Avatar
Rotor prep is just as important as the brand name. Ok, more important.
You can't just take rotors out of the box and expect to have optimum braking.
Brake Rotor Prep.
Richard Newton
Old 12-24-2016, 07:31 AM
  #35
cre8fun
cre8fun's Avatar
Usually you buy the ring and a fastener set, then remove the old ring from hat and bolt on the new one.
Old 12-24-2016, 07:34 AM
  #36
cre8fun
cre8fun's Avatar
I've been shocked at how well the DBA 4000's have held up. Mine have about 20 track days on them and they are not done. Using Hawk DTC-70 pads which last 5-6 days depending on track.
I agree, Mark's rotors are a work of art. They're essentially a better version of the DBA5000
Quick Reply: What are the best rotors available for stock C5 brakes?
