Accusump remote fill and pressure gauge?
Old 01-09-2017, 11:17 AM
heavyzee
heavyzee's Avatar
Default Accusump remote fill and pressure gauge?
for you guys running an accusump.
Is it worthwhile to plumb the shrader value and the pressure gauge up to the dash, or do you just pull the fender liner after each track use to check the pressure on the backside of the accu-sump?
Old 01-09-2017, 02:07 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
Mine is mounted in the left fender well. When I open my door, my gauge is pointed so I can see the pressure from there. I do have my schrader valve plumbed to right behind washer tank so I can get to it without removing liner.
Old 01-09-2017, 04:26 PM
Rx7Rob
Rx7Rob's Avatar
You can see mine in this thread:
https://www.corvetteforum.com/forums...post1592456225
I did the recommended upside down install which would have put the gauge at the bottom. You could still get to the the gauge and schrader by removing the small plastic panel that goes from the inner fender to under the car. But thats a hassle.
With a remote / gauge and fill make sure there aren't any leaks before closing it back up. I used Loctite 567 (PTFE filled) pipe thread sealant and can't detect any leakdown even after sitting for over a month.
Old 01-10-2017, 01:48 PM
zrtman1
zrtman1's Avatar
That is a clean install. Nice work!
Old 01-11-2017, 04:28 PM
davidfarmer
davidfarmer's Avatar
why would you check the pressure that often? If it is leaking, you will know it since the pre-lube will not function. I've run many of them, and I've never had to re-charge one unless I intentionally discharged it for service. They are double-o-ringed and the aluminum surface is as smooth as glass
Old 01-11-2017, 06:04 PM
Dirk Miller
Dirk Miller's Avatar
Changing subject matter for just a sec....
Hey David,
Are you still making vinyl numbers? I'll need some
dirk
Old 01-12-2017, 02:21 AM
65BSPCORVETTE
65BSPCORVETTE's Avatar
I installed mine just above the assembly on the left fender apron.
Old 01-12-2017, 03:21 AM
trackboss
trackboss's Avatar
On the installs I have done I kept it simple and remotely mounted the shrader valve up near the hood latch. A tire pressure gauge is then used to set and check pressure.
Old 01-14-2017, 09:09 PM
RecMech
RecMech's Avatar
I dont use my wipers, so this has worked out well....
Old 01-25-2017, 03:09 AM
GTR-Z51
GTR-Z51's Avatar
Any pics of where the accusump is located and mounted? I am trying to find the best location for my C6.
Old 01-25-2017, 09:17 AM
RecMech
RecMech's Avatar
Basically the same as everyone else.. This was before I moved the gauge...
Old 01-25-2017, 04:39 PM
GTR-Z51
GTR-Z51's Avatar
Ok, I see that you trimmed the bottom cross piece of the inner fender bracket. I guessing that this did not cause any issues.
Old 01-25-2017, 04:56 PM
RecMech
RecMech's Avatar
No issues cutting that bracket, but you do lose the ability to put the 7mm headed screw back in at about mid height (from the inside).. I was having issues with my fenders sliding back into the doors at speed so I fabbed up these brakets for each side and added 2 dzus fasteners per side..
And from the outside.. Dont mind the blowout!
GTR-Z51 (01-25-2017)
To Accusump remote fill and pressure gauge?
Quick Reply: Accusump remote fill and pressure gauge?
