Accusump
Old Jun 19, 2016 | 07:06 AM
jdm767's Avatar
jdm767
Default Accusump
Does anyone have any experience with an Accusump oiling system?
Specifically I'd like to know where you mounted the tank? I'm thinking of mounting it to the hardbar behind the seats, but then there's a lot of plumbing needed.
What have you guys done?
Thank you!
Jeff
Old Jun 19, 2016 | 07:21 AM
marco383's Avatar
marco383
My 3 quart Accusump is mounted in the driver's side fender adjacent to the firewall. I'm using a manual shutoff valve, which is easily accessed in this location, and have installed a more easily read pressure gauge,
Old Jun 19, 2016 | 11:45 AM
Rx7Rob's Avatar
Rx7Rob
As Marco mentioned, the common location for a 3qt is the drivers fender. I'm using the pressure controlled electronic valve and wired a switch to the interior of the car with super bright LED that get triggered when the EPC valve opens. I also remotely located the pressure gauge and schrader valve. Here are some of my install photos.
Old Jun 19, 2016 | 01:32 PM
jdm767's Avatar
jdm767
that really helps! Thank you!!!!
Old Jun 19, 2016 | 10:42 PM
gimp's Avatar
gimp
Some questions for you guys -
What did the install cost? Or, if you did it yourself, how long did it take you?
Why did you choose the switches you did? I feel like wiring it to the ignition makes a lot of sense, so it stores pressure when the car is off and immediately helps oil the engine as soon as you turn the car on.
Old Jun 20, 2016 | 12:39 AM
Last C5's Avatar
Last C5
I installed mine in the space in front of the radiator and accessed the front left oil galley. Works fine.
Old Jul 11, 2016 | 12:24 PM
danh52's Avatar
danh52
Do you have any pictures of your install?
Old Jul 11, 2016 | 01:29 PM
marco383's Avatar
marco383
I went with the manual valve because I don't trust electrical units. I usually close the valve at the end of a run with the engine pressurizing the Accusump with 50 psi or more. I then open the valve to prelube the engine just before firing it up.
Old Jul 11, 2016 | 03:23 PM
YYZ06's Avatar
YYZ06
Nice install!
Old Jul 12, 2016 | 11:07 PM
Last C5's Avatar
Last C5
Old Jul 20, 2016 | 12:14 PM
PMorganRacing's Avatar
PMorganRacing
CorvetteForum Editor
Default Front page news!
Figured the front page would want to check this out too...
https://www.corvetteforum.com/articl...ettes-install/
Old Jul 21, 2016 | 01:42 AM
Dirk Miller's Avatar
Dirk Miller
Default behind seat Accusump install
PICTURES CAN BE SEEN BY GOING TO FOLLOWING PHOTOBUCKET:
http://s1111.photobucket.com/albums/...with%20hithch/
Old Feb 25, 2017 | 01:23 PM
YYZ06's Avatar
YYZ06
Did you fabricate the block that mounts the pressure gauge and schrader valve or can it be purchased somewhere? What size AN hose/fittings are you using to go to the remote pressure block?
I'm gathering the parts to install an Accusump in my car and really like your remote setup.
Old Feb 25, 2017 | 04:39 PM
Rx7Rob's Avatar
Rx7Rob
The multi-port block came from Summit. I made the bracket to hold the pressure gauge, bracket to hold the valve, and inner fender plate.
I also added diodes to block the back emf that occurs when switching large inductive loads like the solenoid valve and a relay switched from inside the car. The switch has a power light and I added a super-bright white LED that turns on when the sump dumps.
There are many different ways of putting it together. I used a straight adapter fitting at the front oil galley plug and went to a 45° AN. That frigg'n AN connector was a nightmare. I don't know if all the brands are the same but I could not tighten the AN without it rotating the 45 away from the position I wanted. I tried assembling dry and lubed. The swivel on the AN fitting is at the back side where the hose connect. It really needs to be at the front side before the 45.
Heres my parts list ....
Summit Racing:
- Moroso MOR-23900 Engine Oil Accumulator, 3 Quarts, $202.97
- Canton Racing Products 24-200 - Mounting Clamps CTR-24-200
Oil Accumulator Mounting Brackets, Stainless Steel, Natural, Kit
(Mfr. #: 24-200), 1 pair $17.00
- CTR-24-273X ACCUSUMP EPC VALVE KIT (Mfr. #: 24-273X), $222.00 [this is with the 35psi switch, you'll want a lower pressure switch for street use or will dump every time you drop to idle]
- Earl's Performance 9919FFJERL - Earl's Performance AN to Metric Adapter Fittings
Fitting, Straight, AN Flare to Metric, -10 AN to 16mm x 1.5 Male, Aluminum, Blue Anodized, Each
(Mfr. #: 9919FFJERL),$11.97
- Summit Racing SUM-230006 - Summit Racing® Stainless Steel Hose SUM-230006
Hose, Braided Stainless Steel, -10 AN, 6 ft. Length, Each
(Mfr. #: SUM-230006), $39.97
- Aeroquip FBM2009 - Aeroquip AN to NPT Adapter Fittings AER-FBM2009
Fitting, Straight, -10 AN Male to 1/2 in. NPT Male, Aluminum, Blue, Each
(Mfr. #: FBM2009), $4.97, qty: 3, $14.91
- Summit Racing SUM-220447 - Summit Racing® AN to NPT Adapter Fittings SUM-220447
Fitting, Adapter, Straight, Male -4 AN to Male 1/4 in. NPT, Aluminum, Blue Anodized, Each
(Mfr. #: SUM-220447), $2.75, qty:2, $5.50
- Summit Racing SUM-220087 - Summit Racing® Hose Ends SUM-220087
Fitting, Hose End, 90 Degree, -10 AN Hose to Female -10 AN, Aluminum, Red/Blue Anodized, Each
(Mfr. #: SUM-220087),$17.97
- Summit Racing SUM-220090 - Summit Racing® Hose Ends SUM-220090
Fitting, Hose End, Straight, -10 AN Hose to Female -10 AN, Aluminum, Red/Blue Anodized, Each
(Mfr. #: SUM-220090), $9.97, qty:2, $19.94
- Summit Racing SUM-220086 - Summit Racing® Hose Ends SUM-220086
Fitting, Hose End, 45 Degree, -10 AN Hose to Female -10 AN, Aluminum, Red/Blue Anodized, Each
(Mfr. #: SUM-220086), $16.97
- Summit Racing SUM-230403 - Summit Racing® Stainless Steel Hose SUM-230403
Hose, Braided Stainless Steel, -4 AN, 3 ft. Length, Each
(Mfr. #: SUM-230403), $14.97
- Summit Racing SUM-220487 - Summit Racing® Hose Ends SUM-220487
Fitting, Hose End, 90 Degree, -4 AN Hose to Female -4 AN, Aluminum, Red/Blue Anodized, Each
(Mfr. #: SUM-220487), $14.97
- Summit Racing SUM-220490 - Summit Racing® Hose Ends SUM-220490
Fitting, Hose End, Straight, -4 AN Hose to Female -4 AN, Aluminum, Red/Blue Anodized, Each
(Mfr. #: SUM-220490), $5.97
- Edelmann 226200 - Edelmann Pipe Thread Plug Fittings EDD-226200
Fitting, Pipe Plug, 1/8 in. NPT Male Threads, Internal Allen Head, Brass, Natural, Each
(Mfr. #: 226200), $1.25
- Edelmann 210420 - Edelmann Pipe Thread Reducer Fittings EDD-210420
Fitting, Pipe Thread Reducer, Straight, Brass, 1/8 in. NPT Female Threads, 1/4 in. NPT Male Threads, Each
(Mfr. #: 210420), $1.97
- Fragola Performance Systems 999216 - Fragola Performance Systems AN Crush Washers FRA-999216 Crush Washers, 16mm, Aluminum, Set of 10
(Mfr. #: 999216), $5.97 [THESE ARE JUNK and not the correct dimension, I ended up ordering from McMaster 97725A107 $14.40 for 25]
- Viair Corporation 92821 - VIAIR Multi-Port Fittings VAR-92821
Fitting, Multi-Port, Aluminum, 1/4 in. NPT Female, 1/4 in. NPT Female, 1/8 in. NPT Female, Each
(Mfr. #: 92821), $2.95
Old Feb 26, 2017 | 12:32 PM
YYZ06's Avatar
YYZ06
Summit Racing:
Awesome! Thanks a bunch!
Right now I'm thinking about "T"ing off of my oil cooler return line. I just got the fender off yesterday and will start looking around to see what clearances I have and what else I need to disassemble.
I ordered the 35-40 lb EPC valve and I like the idea of an indicator for when the system dumps. Not being an EE, I don't really understand the statement "... to block the back emf that occurs when switching large inductive loads like the solenoid valve and a relay switched from inside the car." Do you have any pictures? Canton sells an indicator LED (PN 24-295), would it serve the same purpose. I'll have to get one of my EE friends at work to explain it to me.
Old Feb 26, 2017 | 02:33 PM
Rx7Rob's Avatar
Rx7Rob
Now thats funny! Back when I did it, Canton told me you can't use an LED indicator because it would pop. I explained to them about back EMF and how to resolve (I have all the emails). I even sent them o-scope traces that I measured off their valve as well as the reduction with diodes.
Old Feb 27, 2017 | 01:45 PM
ImprovedRacing's Avatar
ImprovedRacing
Supporting Vendor
Sounds like you taught them how to make their LED light kit, lol!
__________________
Contact Us
Follow Us: Facebook - Instagram - Youtube
To Accusump
Old Feb 27, 2017 | 08:16 PM
Rx7Rob's Avatar
Rx7Rob
Ah, no big deal. Its not like it was a big secret to make it work, just a clamping diode across the solenoid. Should increase the life of the pressure switch as well. Dropped the inductive kickback from >300v to less than 1.
Old Feb 28, 2017 | 10:19 AM
ImprovedRacing
Supporting Vendor
The back EMF was over 300V? I can see how that might blow the LED.
Old Feb 28, 2017 | 01:07 PM
YYZ06's Avatar
YYZ06
I took auto shop in high school not electronics so all this talk of diodes makes my eyes glaze over. If I was to purchase one of the Canton LEDs is there a way to tell if they incorporated a diode into the unit? Ohm meter maybe?
