Steering column rebuild
Old 02-08-2005, 10:30 PM
GTS34
GTS34's Avatar
Default Steering column rebuild
Anyone ever have their steering column rebuilt? I took my 67's column apart to sandblast, repaint, and inspect and I was debating whether or not to reassemble myself or send it out (I took it apart awhile back so my memory of how it goes back together might be a little fuzzy). I plan on replacing the bearings, etc. All I see listed is rebuild services for the tele column?
Old 02-08-2005, 11:33 PM
bondtimbond
bondtimbond's Avatar
I did it myself and its not that hard. All parts came from LIC. If you can't remember how it went together that could be a problem however...
Also, you have to figure out if you have an early 67 design or later design. They are different in the lower bearing area.
Old 02-09-2005, 09:09 AM
GTS34
GTS34's Avatar
I have a late 67 (car was built June 67). It doesn't seem to hard to go back together, I just figured I need new bearings, etc so I thought I would see if anyone offered a rebuild service or if I should just order the parts and do it myself. I did take it apart some time ago, and can't find any diagrams showing the steering column though?
6tee6
6tee6's Avatar
Like Tim, I did mine myself. Ordered some replacement parts from LIC and put her back together.
I also, had waited a while to reassemble after taking it apart. I used the AIM along with the exploded view available in the LIC catalog and surprisingly enough it went right together.....Turns right and left, signals work and no parts left over...
Old 02-09-2005, 03:40 PM
DZVette
Support Corvetteforum!
DZVette's Avatar
Not difficult at all (mine is a 1965 non-tele). I can send you some pics of that tonite if you want them.
Check out Sect 18 of the LIC catalog here:
http://www.licorvette.com/pdfcatalogfiles/cat23/18.pdf
Their pics might be useful to you.
DZ
Old 02-10-2005, 12:21 AM
GTS34
GTS34's Avatar
Any pics would be appreciated. The one thing I can't seem to figure out is where one of the plastic spacer (collar)? goes. Not the black one that goes at the bottom, there is a yellowish clear looks like a gear on the outside, and is round on the inside and has a split in it (circled in red in the pic). When I disassembled the column it was just floating on the shaft in the crumple zone area of the column. This one definitely goes inside the tube housing unlike the lower one. Also any suggestions on what to use to cover the crumple area, I removed the original thin plastic cover, and electical tape which held it before I sandblasted it.
To Steering column rebuild
Quick Reply: Steering column rebuild
