I love dynamat!
Old 03-20-2006, 02:17 PM
Mikey65
Mikey65's Avatar
Default I love dynamat!
I drove the vette for the first time today after installing the carpet and dynamat.. wow what a difference. All that random rattling and little sounds have gone away completely. It feels and sounds so much better. I definately suggest Dynamat Xtreme.
Old 03-20-2006, 02:49 PM
Corbrastang
Corbrastang's Avatar
Makes the car sound a lot more solid and keeps your feet cooler too. Well worth the money. It also makes the carpet fit alot better than compared to using the original type insulation.
Old 03-20-2006, 02:55 PM
Mikey65
Mikey65's Avatar
I used the Jute Padding as well.. so it was still a major pain in the ****. But man this stuff is sweet. It does feel so much more solid..
Old 03-20-2006, 03:15 PM
EWJ
EWJ's Avatar
So you should use it in place of the original padding?
Old 03-20-2006, 03:22 PM
Black60
Black60's Avatar
What sold me was the ease of installation. No overspray problems, no gluing and caulking, just peel and stick. Can't wait to actually drive my car.
R
Old 03-20-2006, 03:28 PM
Mikey65
Mikey65's Avatar
R
I know what you mean.. Time consuming, but very easy and I put it everywhere.. I wonder how hard it will be to remove it if I ever have to?
Old 03-20-2006, 04:58 PM
Birdball
Birdball's Avatar
How much sq. foot do you guys recommend for a C2 and would you use it instead of the jute padding? Which dynomat? Approx cost to do a midyear?
thanks! good thread...
Matt
Old 03-20-2006, 05:27 PM
Mike'sincorrect66
Mike'sincorrect66's Avatar
Old 03-20-2006, 07:08 PM
Corbrastang
I've used the fatmat and the dynomat. The dynomat is more expensive, but it is thicker and does not have a pungent odor like the fatmat.
I use it in place of the jute backed padding. It just makes the carpet fit sooo much better. Whenever i have used the orignal type padding the carpet bunches up or refuses to sit or stick down correctly regardless of how much adhesive is used. With the dynamat you just roll it into place and glue the carpet directly on top. It might seem odd that something so thin could take the place of the original padding, but trust me it does and is far superior. Technology is a wonderful thing. I purchased mine off of ebay for a great discount. One bulk pack does the front.
Old 03-20-2006, 08:06 PM
Mikey65
Mikey65's Avatar
I bought 2 bulk packs and had 2 sheets left over.. I put it everywhere..
Old 03-20-2006, 09:46 PM
CoupeKeeper
CoupeKeeper's Avatar
I also used a heat shield over the dynamat, it was mentioned on the forum some time ago. I think it was called Reflectex? I used metal tape to adhere it to the dynamat and then glued the carpet down to it. Not only did I get the sound deadening, but got much cooler too!
Old 03-20-2006, 09:59 PM
64roadster
Support Corvetteforum!
64roadster's Avatar
St. Jude Donor '07
How many square feet are required to cover a mid year convertible, or a coupe? If no one knows I suppose I can measure my new carpet..
Old 03-20-2006, 10:41 PM
Mikey65
Mikey65's Avatar
I used about 50 square feet
Old 03-20-2006, 10:47 PM
64roadster
64roadster's Avatar
St. Jude Donor '07
Thanks Mikey, maybe I'll make a trip to our new Summit store this week.
Old 03-20-2006, 11:00 PM
Larry99
Larry99's Avatar
Someone told me that I can use Dynamat under the tops of my C-1 front fenders to keep stones from creating "stars' in my new paint. This would be an alternative to using spray undercoating. Anyone had any experience in this area?
To I love dynamat!
Quick Reply: I love dynamat!
