Emergency Brake cable Clips
On the Emergency brake cable sheave located on the trailing arm, there is a clip holding it where it transistions to plain cable. I have purchased stamped metal clips from LICS and they do not work, but I have seen a spring wire formed clip and was wondering where I can get these?
Thanks,
Charlie
Thanks,
Charlie
Assume this is the clip that holds the cable to the bracket on the trailing arm? Wonder too why the spring steel clip did not work. Should have been fine unless there was a mod to the bracket or the cable is not correct (or you got a bad clip!)
Anyway...an E-ring from your local hardware store will work too, if you're not worried about NCRS points..
A good parts store may have all of these original type wire and spring clips (probably a Dorman product)..
Harry
Harry
I used "mickey mouse clip" to attach my e-brake cables to the trailing arm...they hold just fine.
I bought mine from the local vette restorer here in my home town..
try Corvette Central i have had goood results from them..
jack
jack
Received 1,857 Likes
The wire "mickey mouse" clips are correct for the parking brake cable sheath attachment, both at the frame corner and at the trailing arm. They didn't show up in the Assembly Manual until '67. The NCRS JG's still show the flat spring steel U-clips (which are only used on brake hoses), and will be changed in their next revision. Photos below are from an untouched Bowtie car.
Jack is correct. "Mickey Mouse" clips are the "parking brake cable retainer clips" used on both ends of the shielded section of the cable where it clips to frame and TA. All of the major vendors carry them and you might try your local auto parts houses or a local Chevy dealer. The flat clips are used for the rubber brake hose fittings, etc.
Check out his link:
http://www.inlinetube.com/images/bra...lips/clips.htm
DZ
And JohnZ too! Beat me in while I was dinking around!
Check out his link:
DZ
Check out his link:
DZ
Check out his link:
DZ
Got it will try local autobarn this week
