Need help with 67 wiper switch/motor wiring
Old 03-22-2009, 07:34 PM
1coolC2
1coolC2's Avatar
Default Need help with 67 wiper switch/motor wiring
I'm getting around to knocking out the last of the "left over" stuff...you know, the things that did not work out after getting the car all back together and did not stop you from driving it. I used a Painless wiring harness and for the most part everything worked out great.......with the exception of the wiper system. Here's the deal....I have a wiring diagram for 67, but I can't really tell which wire goes on which post because I did not have the original harness to determine how they were orientated in the plug. I made up a diagram (see below) as to how I currently have it hooked up. Here is what I am getting for operation...
In the off position (all the way left) I have slow wipers.
In the slow position I have slow wipers.
In the fast position, the wipers turn off and park........
Can someone give me the wire colors (1967) and what post they are assigned to. I really don't want to start swapping around the wires and cooking a perfectly good wiper motor that was done by Dave Hackel.
Thanks in advance for your help!!
R/Jeff
Old 03-22-2009, 08:09 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Here's how the circuit works, and which contacts are grounded (through the switch body to the cluster) for each function:
Yellow & light blue grounded = low speed
Light blue only grounded = high speed
Dark blue grounded (push button) = washer pump
Old 03-22-2009, 08:48 PM
1coolC2
1coolC2's Avatar
John,
That tells me I have the dark blue and light blue wire reversed on my switch. Do you have a diagram of the wiper motor side?? If not, can you take a look at your 67 and tell me if the two prong plug has the brown wire on top with dark blue on bottom and what is the order of the wires front to back on the three prong flat plug that plugs in on the bottom of the motor .
As always, thanks a million John!!
R/Jeff
Old 03-23-2009, 01:40 AM
buns
buns's Avatar
It appears that the orientation of the male terminals on your switch are different than the ones on my '66, but I believe the wiper motors are the same so this diagram should help.
Regarding the brown and dark blue wires that go to the washer pump, they can go on either terminal. They are just completing a circuit.
Old 03-23-2009, 05:53 PM
1coolC2
1coolC2's Avatar
Tim,
Thanks for the GREAT diagram!! Will swap my wires around and see what we get....hopefully not smoke!!
R/
Jeff
Old 03-23-2009, 09:32 PM
1coolC2
1coolC2's Avatar
Ta - Da..................man, sure works better when you have it wired correctly! To think I managed to wire the entire car including all the fuel injection, AC, power windows, seats and a pile of other goodies and the dang wipers kick my butt
Thanks again JohnZ and Buns
R/
Jeff
Old 08-30-2009, 08:34 PM
Tauvette
4th Gear
Tauvette's Avatar
Default 65 wiper switch problem
May I get your help with a similar problem?
I can bench test my 65 wiper motor directly to the battery without the switch and it works fine. When I try to use the switch (I've tried a 67, a 64 plus a 66 Tempest switch) I can only get it to run in High! What the heck am I doing wrong? I find it hard to believe all 3 switches are defective. Please enlighten me. Thanks: *****:
Old 08-31-2009, 08:23 PM
1coolC2
1coolC2's Avatar
Sounds like your yellow wire is not applying ground to the motor. Ensure the wire is not broken between the switch and the motor. It sounds like the motor is fine if you can ground both spades and get low speed. I would do a continuity check on the yellow wire as a first step.
R/Jeff
Old 08-31-2009, 08:49 PM
Tauvette
4th Gear
Tauvette's Avatar
Thanks Jeff I'll try it after work tomorrow and let you know. Cheers, *****
Old 09-05-2009, 08:39 PM
Tauvette
4th Gear
Tauvette's Avatar
Success! Thanks for all your help.
Old 09-05-2009, 08:57 PM
Tom Austin
Tom Austin's Avatar
Received 1,962 Likes on 664 Posts
Jeff,
Now that the wipers are working . . . are you going to drive that gorgeous car in the rain??? NOT!!!
Tom
Old 09-06-2009, 06:00 PM
1coolC2
1coolC2's Avatar
Originally Posted by Tom Austin
Jeff,
Tom
Tom,
Already had to a couple of times. Wipers are not an issue when your to busy trying to keep the water on the OUTSIDE!! That's one of the things I need to relook this winter when I am doing some of the warranty repairs
R/Jeff
Old 10-17-2009, 01:32 PM
jlagarde
jlagarde's Avatar
This is a great photo. My 66 motor has a terminal tab right above the 3 tab connector but I don't see it on yours in this photo. You can see it on the 1st post illustration. This tab has 12 volts on it when the 3 wire plug is connected. Does anyone know why that single tab is on mine and not on this one and what it's function may be? The car was rebuilt and I don't know if maybe it's a different year unit.
Joe
Old 10-17-2009, 01:48 PM
jlagarde
jlagarde's Avatar
Found it!
For whatever reason, there is a tab sticking straight up (very inviting and begging for a connection) that is part of the center (possitive lead) of the 3 wire connector.
Don't know why its there but it's caused some hard head scratching.
Joe
Old 10-18-2009, 05:58 AM
Tauvette
4th Gear
Tauvette's Avatar
As posted earlier I got my wipers to work with the help of the diagrams and guidance from this site. Thanks again y'all.
Now hears a head banger!
Whenever I start the car the wipers immediately come on high and I have to fiddle with the switch to turn them off?. Sounds like a defective switch to me but I was wondering if anyone else has had a similar problem.
Cures to those used parts on eBay. LOL
Old 02-07-2017, 07:00 PM
RoudyRick
RoudyRick's Avatar
Default Thank you
Thank You, You helped me 8 years after posted
Old 02-18-2017, 10:28 PM
Rubc555
Rubc555's Avatar
Hey guys I got a ? I just got this 66 last month and the window washer pump was gone.
I got all the parts to build it back ..
Thing is I'm not sure how the cap with the 3 nipples that the hoses connect to are orientated to the pump.. any photo would help .. I can't find any that show how it suppose
To bolt up for sure...
To Need help with 67 wiper switch/motor wiring
Quick Reply: Need help with 67 wiper switch/motor wiring
