I am installing a new crate GM engine in my 64, while trans is out I am replacing most of the seals in the trans and cleaning everything up as I go along. My concern with the clutch gear shaft (the shaft with 10 splines that goes thru the clutch disc and into the pilot brg in the end of the crankshaft. It has a fair amount of end play in it, guessing it is an1/8" or so, is this normal? Am going to put a new frt seal in the clutch gear brg retainer, could the clutch brg retainer nut need to be tightnened up
to take out some play? Also the new pilot brg I got with the clutch kit has some magnetism in it, read some where that you should boil in oil for a few minutes, or is this an old back yard tale? Thanks for any advice on these issues and if I should go another way.
Radial play in the clutch gear is normal in a transmission with any miles on it. Some are really sloppy.
I agree. Totally normal and not a concern. If it had no play, something would be wrong. The pilot bushing/bearing supports the 'floppy' end of the shaft when the trans is installed, and it doesn't flop around at all.
