1964 expansion tank overflow hose routing?
The overflow hose routing goes mostly on all pictures i look at down towards the ground close to the expansion tank but i have seen pictures of the overflow hose going to the radiator and down by the radiators side(under the radiator clips)
Wich routing for the overflow hose is right?
2016 C2 of the Year Finalist
According to the 64 Judging Guide "A thin walled, black overflow hose is connected to a nipple on the expansion tank neck, routed downward between the inner fender and frame, terminating at the bottom of the frame rail". Hope that helps........ Dave
I routed the overflow hose affter i painted the engine bay towards and down side the radiator wich is wrong. I saw this routing on some schematics wich i cant find again. I think it might be like this for the C1.
Rerouted the overflow hose again today downwards between the inner fender and frame, terminating at the bottom of the frame rail. As described by Dave
Thanks for your help Dave
