Pilot bearing vs bushing
Old 02-20-2012, 12:31 PM
65tripleblack
65tripleblack's Avatar
See post #9.
Muncie and Richmond trans have a lot of slop in the input shaft which makes bellhousing alignment somewhat more forgiving. Later trans like the TKO, T45 and T56 do not. These will destroy a pilot bearing in short order and will quickly wear out a bushing if the bellhousing is not within their specified runout dimensions.
An added benefit of concentricity is ease of shifting, especially at higher RPM's.
GM issued bellhousings are notorious for "marginal" and excessive runout as relates to use of a modern transmission. Not surprising, as everything from GM, back in the "good old days" had huge tolerances and very poor quality control.
65tripleblack is offline
Old 02-20-2012, 12:49 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
If someone is having problems with the pilot bushings I would highly suggest dialing in your bellhousing. Hardly anyone outside the racing enviroment does this but on all my stick cars I dial the bellhousing in so the input is in direct alignment with the center of the crankshaft, i.e. pilot bushing.
That is a required step before doing the Keisler Tremec conversion !!
Fortunately my '61 did not require any offset dowels, etc.. and was well within specs..
Frankie the Fink is offline
Old 02-20-2012, 12:58 PM
Dave64
Dave64's Avatar
2023 C2 of the Year Winner - Modified
2021 C8 of the Year Finalist - Unmodified
2019 C2 of Year Finalist (appearance mods)
St. Jude Donor '19-'20-'21
Originally Posted by Frankie the Fink
Interesting - since Kiesler requires a needle bearing on their Tremec conversions to meet the warranty conditions. Luckily I haven't had any trouble so far or else I have and it hasn't manifested itself yet!
My Tremec 600 didn't come with a needle bearing bushing. It came with an aftermarket-looking, silverish-colored bushing, which I chucked for a good bronze bushing from GM.
Dave
Dave64 is offline
Old 06-02-2016, 10:49 AM
44Lawrence
2nd Gear
44Lawrence's Avatar
Default Pilot rolling bearing
pilot bearing or bushing. My change over from auto to TKO 600 manual about 8 years, 10k miles ago in my 91 12cyl Jaguar (please no jokes) came with the pilot bearing in the kit from Driven Man. I didn't dial in the bellhousing center line, should have but didn't. Fast forward to last year, needed throwout bearing work. Long story short, very lucky I guess. The pilot bearing looked new, repacked it put it back together.
Lawrence
44Lawrence is offline
Old 06-02-2016, 11:58 AM
ejboyd5
ejboyd5's Avatar
Originally Posted by FlaVert
I was always told, "Bushings wear, bearings FAIL."
I could never understand why anyone would install something with multiple moving parts, i.e., failure points, when there is a perfectly good one-piece alternative.
ejboyd5 is offline
Old 06-02-2016, 12:41 PM
GTOguy
GTOguy's Avatar
Received 3,443 Likes on 2,113 Posts
Have been running BALL bearing pilot bearings for the past 40 years in all my 4 speed GTO's with no issues and for 100's of thousands of miles, with a lot of abuse. Pontiac specifies a ball bearing, and NOT a bronze bushing. That said, bearings can dry out and fail, and when they do, their hardened parts can wreak havoc on other components. Bushings are 'cruder', but are pretty bulletproof. Have no idea what's in my '61 'vette.
GTOguy is offline
Old 06-02-2016, 01:08 PM
44Lawrence
2nd Gear
44Lawrence's Avatar
I look at it this way. I got 10yrs to date, still looks new, no noise, vibrations etc. I was not about to "fix something that wasn't broke" or play with fitting a bronze bushing, "been there done that". So, is there an advantage pilot bearing over bronze bushing? I surely don't know. I never had either fail, but this is my first time with a pilot bearing .
Lawrence
Old 06-02-2016, 07:11 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
I prefer the NON MAGNETIC bronze bushings myself. I have several bronze bushings from clutch kits that a magnet will stick to and i can not bring myself to use them...and purchased the original design which is NON magnetic.
I have also used the roller bearing design on 6-speeds I have done and the Tremec transmission that they required to be used. And when I took out the roller bearing on the 6 speeds I have done it was fine and it was being replaced because the clutch needed to be replaced....and these cars were HIGH miles...50K + miles.
I myself have wondered WHY the design change on this pilot bushing bearing area and someone told me that the roller bearing was more precise. I do not know if I 'buy' that explanation.
I do check the bore concentricity...and correct it if needed.
And I can say that when installing the pilot 'whatever you choose'...I am careful not to damage it in any way so the input shaft does not stick or bind on it...which can cause for problems in the clutch engaging when the engine is running.
I am going to hopefully re-work a press I have made that bolts to the crank shaft and allows me to press the bushing in. It works but it is really crude an the next time I do a clutch and I have the time to do a bit more R & D...I plan on trying to get it 'better'. Right now it takes a lot longer to set it up my tool than tap one in....but it something that i just kinda want to do.
DUB
DUB is offline
Old 06-02-2016, 07:17 PM
jdk971
Support Corvetteforum!
jdk971's Avatar
what would happen if you use a metallic pilot bushing? thanks jim
jdk971 is offline
Old 06-02-2016, 08:05 PM
Powershift
Powershift's Avatar
Received 1,681 Likes on 1,307 Posts
Accelerated wear on the transmission input shaft nosepiece. See pics about halfway down the page. http://www.crankshaftcoalition.com/w...g_and_bushings
Larry
Powershift is offline
jdk971 (06-03-2016)
Old 06-02-2016, 08:08 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
I've never heard of a ball pilot bearing..
Bill
wmf62 is offline
Old 06-02-2016, 08:27 PM
Powershift
Powershift's Avatar
Bill
Most have needle bearings............but a Google search does show a few ball bearing pilot bearings that are out there in cars.
Larry
Old 06-03-2016, 08:14 AM
  #33
71scgc
71scgc's Avatar
Who or where is a good source for the bronze or oilite pilot bushings?
I did a TKO 600 conversion on my '71, and used the supplied pilot bearing. I was skeptical...
I don't have many miles on the setup (< 1000mi). It will be coming out soon for a engine change and I would like to use a proper bushing in the new engine, rather than the bearing, and will dial out the Quick Time bell as well.
Carter
71scgc is offline
Old 06-03-2016, 08:40 AM
  #34
DZAUTO
DZAUTO's Avatar
Received 3,772 Likes on 1,674 Posts
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Bill
I believe some Olds engines used a BALL BEARING pilot bearing. AND, with that said, MANY Olds engines (such as later 455 cranks) are NOT machined for a pilot bushing/bearing because MOST Oldsmobile cars came with an auto tranny (puke, puke, puke), thus, no need for the crank to be machined for a pilot bearing/bushing. When I sent the 455 for the Cutlass to the machine shop, I did not know this. Purely by accident it was mentioned to me that there was no pocket in the end of the crank for a pilot bushing. So I had the machine shop cut the pocket and install a bushing that I furnished. This was back in 1988, and I have had ZERO issues with a bronze bushing in the 455 with a Richmond Street 5sp.
DZAUTO is offline
Old 06-03-2016, 08:51 AM
  #35
Vet65te
Vet65te's Avatar
Received 1,032 Likes on 671 Posts
Just about all of my project cars have been Chevys and never ran across a factory ball type pilot bearing until I was reassembling my '64 GTO. It kinda looks like a small ball type axle bearing. Since the GTO was put together around 2002, I've only put a couple thousand miles on it and no problems. After the disintegration of the GM needle pilot bearing in my 66 L79, I won't be using that style anymore in the Chevys.
Mike T - Prescott AZ
Vet65te is online now
Old 06-03-2016, 09:49 AM
  #36
59 navy
59 navy's Avatar
Default pilot bushing concern
I don't mean to crash this thread but I have a question. I replaced the bronze pilot bushing in my 59 but could not get it far enough in to be flush. It is out by 1/4 of an inch. I was told the tranny would hold it in place. Is this going to be a problem? 59 navy
59 navy is offline
Old 06-03-2016, 10:56 AM
  #37
GTOguy
GTOguy's Avatar
Navy, it needs to be all the way in. The trans is not supposed to hold it in place....if it is, the mainshaft shoulder is jammed up against the protruding bushing, causing unwanted pre-load on the trans. Whether bearing or bushing, I always place it in the freezer for an hour or so so that it taps right in easily. Works like a charm.
GTOguy is offline
To Pilot bearing vs bushing
Old 06-03-2016, 11:51 AM
  #38
Stingxray
Stingxray's Avatar
Default Bushed
I ignored Keisler warranty requirement for the Roller pilot on my SS700 Trans. I "DID" however dial in the scatter shield run out to +/- 0.003 . Great product below
http://www.robbmcperformance.com/products/dowels.html
Napa # for the Bronze Pilot Bushing. BK 6151161
and O'Reilly store under the Federal Mogul # PB-656-HD.
Be Sure to take a magnet with you and verify it's Non Magnetic.( No Iron )
Please Note: the pilot Bearing/ Bushing only come into play when the clutch is disengaged, pushed in.
Stingxray is online now
71scgc (06-04-2016)
Old 06-03-2016, 12:15 PM
  #39
4 Speed Dave
4 Speed Dave's Avatar
Larry
In my Nova with a G-Force G101 transmission the input shaft splines are cut back farther which allows the use of a large ball bearing type to be used. NOTE: You can't use this on regular Muncie or ST-10 transmissions. So there are applications where a ball bearing style is used. The bearing has a collar that presses into the back of the crank in the space where a torque conv snout would normally go.
4 Speed Dave is offline
Old 06-03-2016, 01:23 PM
  #40
Powershift
Powershift's Avatar
Carter
That information is in the archives, and I think was also a recent thread here. So check past threads. Here it is: https://www.corvetteforum.com/forums...t-bushing.html
GM still sells one, although it is a bit different than the 1950-60 originals. Also contact Autogear, who participates here on this C2 forum. They say they have them for sale. Probably better than the new GM ones.
Larry
The following 2 users liked this post by Powershift:
71scgc (06-04-2016), Frankie the Fink (10-18-2019)
Quick Reply: Pilot bearing vs bushing
