Starting on a 66 basket case
#41
I just posted another video on youtube. I have a couple questions for the Corvette guys to help me answer about the driveshaft markings.
http://www.youtube.com/watch?v=mYxYYEgJPAM
#42
Received 1,857 Likes
You have an excellent technical reference library, but the one book I don't see, which has ALL the detail information you need for a correct restoration, is the NCRS 1966 Corvette Technical Information Manual & Judging Guide (247 pages); it's available from the NCRS on-line store at www.ncrs.org.
#43
Photo attached of an original driveshaft, showing the blue and orange paint rings and the green dab at the rear; the green dab (which signifies the light side of the trunnion after balancing) was to be aligned with a blue paint dab on the pinion flange when installing the driveshaft (see note in your Assembly Manual, UPC 4, sheet A2). All midyears used exactly the same driveshaft, regardless of engine/transmission/diff combination.
I plan on getting that book I just joined NCRS this week. The car isn't going to be a full blown restoration because I plan on driving it on nice weekends. I want to get things right so that down the road if someone wants to make it a fully restored garage queen they will have a very good car to work with. I also want to bring up things like casting #s and dates and how it is suppose to look even if I don't do it that way so guys can look at my videos and the comments to get answers to questions they may have on their midyear.
#44
Wow, what a project. My '66 was an 8 year restoration, finished in 1986. You've already gotten some great advice about pictures, zip lock bags, label everything, throw nothing and take more pictures as you go. Enjoy the journey. Looking forward to your updates. Here's a little something to get your imagination going.
Kevin
Kevin
#45
[QUOTE=KS69Coupe;1581511507]Wow, what a project. My '66 was an 8 year restoration, finished in 1986. You've already gotten some great advice about pictures, zip lock bags, label everything, throw nothing and take more pictures as you go. Enjoy the journey. Looking forward to your updates. Here's a little something to get your imagination going.
Kevin
Sweet 66 Kevin!! In my one video I showed where I had cabinets on the wall that came crashing down when that happened most of my marked boxes and coffee cans crashed all over the floor so I have lots of stuff to resort. Lucky me
Kevin
#46
Thank you for the info John. Looking at your picture I can see how your driveshaft was raw when the lines and dap were put on there but if you look at mine you can see they were painted over black. My question is did this sometimes happen at the factory? Also your picture has the 2 stripes and dab at the same ends where mine are on opposite ends.
#47
The best advise I can give is that you have to do something just about every day. Even if it is just detailing a part to get it ready to install.
The biggest mistake you can make is doing nothing. Take it little by little and enjoy.
#48
This is real good advise, it is so easy to miss a few days then you go out and think "I didn't get anything done". Next thing you know you are getting fustrated and trying hard to get caught back up which you never do and those little things start to mount and before you know it you lose interest. I know all about doing that because I did it twice with this car. Thank you for your imput!
#49
If i was to restore a C2 now i would restore the car the way i want to and absolute not have the correct overspray paint as the car had when it left the factory
I might even put offset trailing arms and 1" front and 1,5" back original looking fender flares on the car and get some wide wheel on it(might even widen the knock off wheels)
#50
#51
This is something that racks my brain nightly! It will be a driver so I see no need to do it in the poor factory finish. I want to do it right so that down the road if someone wants to make it factory they shouldn't have much problem. Fit and finish will be as I want while still keeping the stock look.
When I installed the transmission a lot of guys suggested that I cut the crossmember. That was a no no in my book. I kept all the parts so the next owner could convert it back to stock if he so chooses.
JMO
#52
#53
IMO, the nice thing about using the original replacement panels is the press molding was done by G.M. ( at least, that is what I understand).
#58
Actually, GM had NO fiberglass manufacturing/molding facilities at all; Corvette fiberglass body panels were all made by outside suppliers and arrived at St. Louis ready to assemble.
