Toilet Paper and a Big Hammer
The title of this thread sounds like a severe personal problem............
I used grease and a socket the last time and it popped it right out - but there was quite a bit of grease to clean up. Next time I'll try this.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
You'll have to show those boys how to use the freezer and the oven make steel do magic tricks.
I use the grease and an input shaft, but next time I'll try the tp....unused.
Wadded up bread works too.
Ok. Call me a dumb azz. What's the actual technique ? I've never done it.
Received 1,921 Likes
1 - whatever you use to drive the wet TP in (vs drive the heavy grease in) does not have to be as close of a fit.
2 - the clean up is way easier - water only.
Okay, there is a third difference - any spatter that shoots out when you go to pound on the whatever you're using to drive it out is far less messy, assuming you're using fresh clean TP.
Same as packing the bore with heavy grease, but with two main differences:
Anyway all this talk of grease, shafts, toilet paper and pounding on things make me thing I'm on the wrong site
The one the wife says I'm not allowed to visit anymore
I used bread, works great, and even less mess than with the paper because no need to add water. As the 'driver' I took a bolt and taped it until it was a fit into the bearing.
I guess nobody will answer my question on exactly how this is done so I'll pose my opinion:
1) Pack the bearing area with TP, bread, whatever, moistened is best
2) Find a punch, bolt, other driver the width of the bearing opening
3) Pound the driver until the packing material drives the bearing out
Is that it ?
Is that it ?
Sorry Frank, Ithought it had been answered. I guess I was envisioning the two types of TP.....butt not for long, lol.
...yes, the method you described is how it's done.
C2 of Year Finalist (track prepared) 2019
2017 C2 of the Year Finalist
Frank,
I am not sticking my whatever in the hole and whacking it with a hammer........
but yes, I used sopping wet TP and a socket
Is that it ?
Is that it ?
