Need tech help on power steering conversion
Old 12-22-2015, 12:08 PM
VetteZr
VetteZr's Avatar
Default Need tech help on power steering conversion
I have converted my 65 over to power steering, but I am having a problem, I personally rebuilt all of the parts, (pump, control valve & cylinder) all new hoses & then when problems arose, I replaced everything with professionally rebuilt parts and of course all of the hoses were new & replaced twice & I have properly installed all hoses each time I replaced them, my problem is that the return hose is building pressure & blowing itself apart, does anyone know what is causing this problem, at this point I am at a loss as to what it could be, thanks in advance for any help offered.
Don
VetteZr@sccoast.net
Old 12-22-2015, 12:22 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Don
VetteZr@sccoast.net
Are your hoses crossed in an "X" pattern at the power cylinder like those in the photo below? If not, they should be - sounds like you may have the high-pressure and low-pressure return lines reversed.
VetteZr (12-23-2015)
Old 12-22-2015, 12:51 PM
VetteZr
VetteZr's Avatar
Yes, that was the very first thing I did when I installed the hoses. but thanks for your input.
Old 12-22-2015, 02:27 PM
XLR8OR
XLR8OR's Avatar
You may have a blocked/stuck valve. I have not had good luck with rebuilt control valves, that's where I would check first. Try bypassing the control valve and see if the problem disappears - if it does, you located the problem.
VetteZr (12-22-2015)
Old 12-22-2015, 02:57 PM
VetteZr
VetteZr's Avatar
Sorry if this sounds stupid, but how do you bypass the control valve?
Old 12-23-2015, 08:31 AM
VetteZr
VetteZr's Avatar
Problem still not solved, any other suggestions.................Please
To Need tech help on power steering conversion
Quick Reply: Need tech help on power steering conversion
