Replacement Clutch
#41
Received 1,843 Likes
#42
2023 Restomod of the Year Finalist
Just picked up my clutch plate after waiting 4 days, and it's much different than my old one. While it is a 10' clutch, it's thicker at the hub by about 3/16" and the disc material is narrower by about 1/4". Also it has 5 springs instead of 6. it says "Valeo", made in Korea.
Does anybody think this is going to matter?
#43
For street use, no.
I'm referring to the sq. in. of facing material, not the Korea part.
#44
If I can't use this clutch plate, then I'll have to discard my good pressure plate & flywheel and buy a compete 11" set, or if someone can tell me what part # I order for a 10" because this is all Napa could find.
#45
If it's not, find another parts store. Those clutch plates are common as dirt.
PS. You NAPA store may be using a computer instead of a parts book or just plain old fashioned product knowledge. If they are, go somewhere else.
PSS. I don't recommend this to you but I've had oil on a clutch disc before to the point where it slipped. I fixed the leak and then smoked the clutch real good, one time and it ran forever without slipping. Don't try this at home.
#46
LUK, Hayes, and McLeod should have a clutch disc to fit your setup. Get one designed for "street" use.
Larry
#47
If that clutch plate is the same outside diameter diameter as your pressure plate, put it in the car and quit worrying about it!
#48
#49
Unless you enjoy yanking transmissions out of these cars I would not try this. My guess is you would have about a 50/50 chance at best of satisfactory results and most likely at least end up with a clutch chatter/shuddering.
#50
Larry
#51
PSS. I don't recommend this to you but I've had oil on a clutch disc before to the point where it slipped. I fixed the leak and then smoked the clutch real good, one time and it ran forever without slipping. Don't try this at home.[/QUOTE]
Maybe you missed the same paragraph?
He never once said his clutch was slipping/chattering, just that it had oil on it.
#53
Received 1,857 Likes
Valeo is a very well-known worldwide supplier of OEM clutches, #2 in the industry (to LuK); their plant in Korea has made clutches for decades.
#54
That's good to know. I installed it & the tranny today. Looks good. Tomorrow I hook up the rest. Hope this puts an end to the tranny leak. Thanks to all for your assistance!
#56
I've put Centerforce II in my small-block 327 '67 and other midyears for many years without disengagement problems, so I'm somewhat mystified about all the problems others have encountered.
#57
Big difference! The old clutch was slipping so badly that operating the clutch was smooth. This new clutch not so, really grabs. I have it adjusted to provide .040 clearance b/t the disc & flywheel/pressure plate. Guess it will have to break in to get smoother.
