Replacement Clutch
Old Feb 23, 2016 | 05:17 PM
  #41
MikeM's Avatar
MikeM
Originally Posted by 59BlueSilver
What car comes stock with this?
Millions and millions and millions of old Chevys.
An (real) oilite pilot bushing doesn't require any lube nor is it a good idea to lube it.
Old Feb 26, 2016 | 03:51 PM
  #42
59BlueSilver's Avatar
59BlueSilver
2023 Restomod of the Year Finalist
Just picked up my clutch plate after waiting 4 days, and it's much different than my old one. While it is a 10' clutch, it's thicker at the hub by about 3/16" and the disc material is narrower by about 1/4". Also it has 5 springs instead of 6. it says "Valeo", made in Korea.
Does anybody think this is going to matter?
Old Feb 26, 2016 | 04:04 PM
  #43
MikeM's Avatar
MikeM
For street use, no.
I'm referring to the sq. in. of facing material, not the Korea part.
Old Feb 26, 2016 | 04:53 PM
  #44
59BlueSilver
Originally Posted by MikeM
For street use, no.
If I can't use this clutch plate, then I'll have to discard my good pressure plate & flywheel and buy a compete 11" set, or if someone can tell me what part # I order for a 10" because this is all Napa could find.
Old Feb 26, 2016 | 04:59 PM
  #45
MikeM's Avatar
MikeM
If that clutch plate is the same outside diameter diameter as your pressure plate, put it in the car and quit worrying about it!
If it's not, find another parts store. Those clutch plates are common as dirt.
PS. You NAPA store may be using a computer instead of a parts book or just plain old fashioned product knowledge. If they are, go somewhere else.
PSS. I don't recommend this to you but I've had oil on a clutch disc before to the point where it slipped. I fixed the leak and then smoked the clutch real good, one time and it ran forever without slipping. Don't try this at home.
Old Feb 26, 2016 | 05:11 PM
  #46
Powershift's Avatar
Powershift
Have your original rebuilt by Fort Wayne Clutch. They have been doing this work for YEARS (and years).
LUK, Hayes, and McLeod should have a clutch disc to fit your setup. Get one designed for "street" use.
Larry
Old Feb 26, 2016 | 11:48 PM
  #47
59BlueSilver
Since I have it out, I wonder if I can solvent clean to remove some of that oil and then burn it. What do you think? It has very little wear.
Old Feb 27, 2016 | 05:48 AM
  #48
MikeM's Avatar
MikeM
Maybe you missed my last paragraph?
Old Feb 27, 2016 | 07:18 AM
  #49
DansYellow66's Avatar
DansYellow66
Unless you enjoy yanking transmissions out of these cars I would not try this. My guess is you would have about a 50/50 chance at best of satisfactory results and most likely at least end up with a clutch chatter/shuddering.
Old Feb 27, 2016 | 12:05 PM
  #50
Powershift's Avatar
Powershift
I would say about 90/10 chance of failure. REPLACE THE DISC.
Larry
Old Feb 27, 2016 | 12:33 PM
  #51
DansYellow66
Larry
I was being optimistic - didn't want to raise MikeM's ire.
Old Feb 27, 2016 | 03:13 PM
  #52
MikeM's Avatar
MikeM
Larry
[QUOTE=MikeM;1591647053
PSS. I don't recommend this to you but I've had oil on a clutch disc before to the point where it slipped. I fixed the leak and then smoked the clutch real good, one time and it ran forever without slipping. Don't try this at home.[/QUOTE]
Maybe you missed the same paragraph?
He never once said his clutch was slipping/chattering, just that it had oil on it.
Old Feb 27, 2016 | 09:15 PM
  #53
JohnZ's Avatar
JohnZ
Valeo is a very well-known worldwide supplier of OEM clutches, #2 in the industry (to LuK); their plant in Korea has made clutches for decades.
Old Feb 27, 2016 | 10:57 PM
  #54
59BlueSilver
That's good to know. I installed it & the tranny today. Looks good. Tomorrow I hook up the rest. Hope this puts an end to the tranny leak. Thanks to all for your assistance!
Old Feb 27, 2016 | 11:00 PM
  #55
59BlueSilver
For street use, no.
Sorry Mike, when I read this, I thought you were saying no to using this clutch disc, and i was running out of options. My mistake...
Old Feb 28, 2016 | 12:38 PM
  #56
LouieM's Avatar
LouieM
I've put Centerforce II in my small-block 327 '67 and other midyears for many years without disengagement problems, so I'm somewhat mystified about all the problems others have encountered.
Old Feb 29, 2016 | 08:01 AM
  #57
59BlueSilver
Big difference! The old clutch was slipping so badly that operating the clutch was smooth. This new clutch not so, really grabs. I have it adjusted to provide .040 clearance b/t the disc & flywheel/pressure plate. Guess it will have to break in to get smoother.
