Noisey speedometer cable
Old 02-19-2016, 05:42 PM
cblankin
cblankin's Avatar
Default Noisey speedometer cable
My speedometer needle is jumping all over the place for the first five or tem minutes. Sound like the speedometer cable needs to be lubricated. I have plans on removing the gauge cluster in a couple months. Till then would it hurt anything to disconnect the cable form the transmission. I have a GPS to tell me the speed. Will transmission oil leak out of the cable connector? Could I just "Cap" it off?
Old 02-19-2016, 10:46 PM
vipervetteguy
vipervetteguy's Avatar
My speedo was acting just as you describe. Then, all of a sudden, the odometer quit working and the speedo instantly became smooth and quiet as can be. I can live w/o an odo, so it's a small price to pay for a smooth speedo.
Old 02-21-2016, 02:12 PM
irwiny
irwiny's Avatar
My speedometer was jumpy and also leaked at the transmission. I lubed the cable twice (didn't help) and is smooth now but both odometer and trip have stopped. I can live with a smooth speedo and non functional odometer and trip meter.
You should maybe put a plate that pushes and keeps the trip reset before they stop. I read it's recommended from senior members here after rebuilding the three worm gears and could reduce the stress on the speedometer.
Old 04-13-2016, 01:52 AM
easyriderknucklehead
easyriderknucklehead's Avatar
\can you please explain the put a plate that pushes and keeps the trip reset. I notice the trip is on other side and hard to reset from front,
Old 04-13-2016, 11:35 AM
irwiny
irwiny's Avatar
Link below reply from Frankie the Fink explains it the best. We are very lucky to have smart guys like him on this forum.
https://www.corvetteforum.com/forums...-odometer.html
Irwin
To Noisey speedometer cable
Quick Reply: Noisey speedometer cable
