[C2] Quick Remove Rear Stingray Emblem
Old 02-16-2017, 12:05 PM
Gofltn1
Gofltn1's Avatar
Originally Posted by 66racer
Best and easy way,cut about 1 inch or more of small i.d. hose that fits snug on prongs,easy on and off and will hold side emblems also
66racer
What is an i.d. Hose?
Old 02-16-2017, 12:09 PM
leif.anderson93
leif.anderson93's Avatar
Received 3,098 Likes on 1,866 Posts
inside diameter...
Gofltn1 (02-16-2017)
Old 02-16-2017, 05:39 PM
woodsdesign
woodsdesign's Avatar
66racer
That has to be a very small hose. I can't see how the prong with a hose pushed on would fit through the holes in the deck.
I wonder if melting some wax on the prongs would work.
Old 02-16-2017, 07:29 PM
66racer
66racer's Avatar
Well you slip hose on AFTER you put emblem on, one will hold it in place 66racer
Old 02-16-2017, 08:13 PM
Gofltn1
Gofltn1's Avatar
The emblem did come with four black plastic covers that kind of look like thick condoms. After trying to find some right sized speed nuts at PepBoys and failing, we cut the "condoms" applied some "Goop" to them and reattached under the nose. Unfortunately, could only get to two prongs but it appears to be working.
Old 02-16-2017, 08:39 PM
rtruman
rtruman's Avatar
Had mine on rear for 17 years pulled it for buffing no problems .
Old 02-23-2017, 08:48 PM
Steve Stone
Steve Stone's Avatar
Both of my side flag emblems and the nose flag emblem are nutted on. My painter provided some barrel clips that fit over the rear Sting Ray emblem stubs. These barrel clips have little wings that spread out to catch the mounting holes. The emblem is easily and carefully removed for waxing. I do not know the official name of these clips.
Old 02-24-2017, 07:14 AM
ejboyd5
ejboyd5's Avatar
Most every company that supplies badges, lapel pins, etc., also supplies retainers in many forms including a soft plastic or rubber formulation. Here's one such company grabbed at random off the web - a search will reveal many more.
http://www.thepinpeople.com/lapel-pi...terfly-clutch/
Old 02-24-2017, 07:35 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
All this to avoid putting some speed nuts on and a little detail cleaning.
Along with possible loss of emblem and paint damage...
I'm not 'getting it'...
Quick Reply: [C2] Quick Remove Rear Stingray Emblem
