Astro Ventilation Actuator, Outside Door Actuator, Defroster Actuator
Does anyone know where to buy either rebuilt or reproduction actuators for the defroster, astro ventilation and outside door?
The part numbers I have are from a 1970 non-a/c car.
Astro Ventilation Door Actuator 1998989
Outside Door Actuator on top of Heater Box 1998948
Defroster Door Actuator on left side of heater box 1998955.
This is for a friend of mine who tried a set from Doc Rebuilt and they did not match and were the wrong size. Turns out Doc Rebuild is getting them from an A/C parts supplier but would not reveal who it is.
cc
cc
i have the original inside heater box from my 70 that i replaced unen i installed a/c. if you're interested in the actuators, i'll check them out to be certain that they operate properly.
jeff
jeff
I emailed my friend your response and will let you know what he says.
In the meantime, did you also seal up your Astro Vent doors under the rear deck? Because they will open everytime you start the car and let all the a/c out. From what I've read, they only close when the heat is on.
He also needs the actuator mounted to the bottom of the rear deck above the window tray.
cc
cc
cc
cc
GD70, not sure how they would work on air cars. Mine has the doors sealed from the factory and there is no actuator or vacuum line. Other threads suggested that no air cars have vacuum actuated doors on the Astro Ventilation system.
cc
cc
Mine has no AC. I believe you're right re: AC cars being sealed up. The owners manual actually gives a lot of detail about this, as well as the Chassis repair manual.
Received 2,878 Likes
Maybe Paragon Vintage (800-882-4688)?
Regards,
Alan
Regards,
Alan
You realize this was 12 yrs ago.
