Body filler for 1982 Vette
Old 01-24-2009, 05:58 PM
kensblue82
kensblue82's Avatar
Default Body filler for 1982 Vette
I have a couple of repairs to make on my door, most notably a crack in the lip of the door just above and behind the door handle. Do I need to attempt a repair using fiberglass matting or is there a mixable filler like Bondo that contains fiberglass I could use. The area I plan to repair is pretty thin so I think it would be difficult to use matting.
Old 01-24-2009, 06:18 PM
eastltd
eastltd's Avatar
Look for "short strand filler" also refered to as Mar-Glass. Depending on the severity of the crack, you may have to use reisin & cloth first.
Be prepared for lots of sanding!
Old 01-25-2009, 09:23 AM
Daffy
Florida turtle advocate
Support Corvetteforum!
Daffy's Avatar
St. Jude Donor '05-'06
Default Short strand filler
USC Duraglass works pretty good...Sand it before it hardens all the way( like an hour after application) and it cuts pretty easy.. grind away the loose stuff before applying...
Old 01-25-2009, 12:50 PM
929nitro
929nitro's Avatar
Duraglass is not SMC compatable. A better product is ProGlass, also made by USC.
To Body filler for 1982 Vette
Quick Reply: Body filler for 1982 Vette
