1969 vette help finding original build sheet
Old Jan 25, 2009 | 11:36 AM
Deej22's Avatar
Deej22
6th Gear
Default 1969 vette help finding original build sheet
Does anybody know how to find original build sheets?
Old Jan 25, 2009 | 11:39 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
If you still have the original gas tank, what'd left of it should be glued to the top of the tank.
Old Jan 25, 2009 | 12:07 PM
Deej22's Avatar
Deej22
6th Gear
The gas tank was replaced. Any other way?
Old Jan 25, 2009 | 12:16 PM
Alan 71's Avatar
Alan 71
Sometimes the shippers copy was stashed behind the dash between the tach/speedo or behind the radio. If your car hasn't been messed with too much over the years it might still be there. Good Luck!
Regards,
Alan
Old Jan 25, 2009 | 01:01 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
Also you could start contacting the PO to find other PO's. This may not get you a build sheet but you could get some history on the car.
Old Jan 25, 2009 | 01:09 PM
wfo76's Avatar
wfo76
Try contacting the previous owner and ask where he got it from and then try to work your way back. Some states DMV offices are more lenient than others and sometimes you can get past title history from them although in this day of paranoia, it is becoming harder if not impossible. Can also go to the library and look through the newspaper classified ads on microfilm if you know about when your car changed hands, maybe an ad was posted there. There was a story somewhere about a guy who found the ad where the original owner sold his car and he still had the same phone listed in the ad from 30 years before. Good luck.
To 1969 vette help finding original build sheet
