1970 Corvette Bronze Questions
I am about to paint my original '70 Big Block 4 spd Convertible. It is a Corvette Bronze car, and I am doing it in laquer. I know, I have heard all of the negatives and positives, but this is a special car I feel, and it has a tank sheet to boot.
When the paint company looks up the formula (They sell PPG Duracryl), it just says 'Dellstar Reference', with no color mix, but they do have a color formula for '68 Corvette Bronze
QUEESTIONS:
1] Is the '68 Bronze the same color / formula? I had been told a while back that they were slightly different, and the paint company guy says that the original GM chips look slightly different, with the '70 color a bit darker. Also on Paintref.com, the color codes for bothe PPG and Dupont on these colors is different year to year.
2] I did find the PPG (2264) and Dupont (5128LM) formulas, but does does anyone know the actual paint mix formula that cros references to PPG?
Thanks,
Dennis Decina
QUEESTIONS:
Thanks,
Dennis Decina
I wouldn't be able to answer your question, but I know different brand paints, seem to have a slight different contrast as a final product.
So if you want exact...check with folks with same color for best choices.
At a glance your paint will look right, but to a perfectionist or next to an exact other, maybe not.
Received 1,470 Likes
Cruise-In II Veteran
Apparently not. http://www.corvettepaintcodes.com/ The codes in the link appear to be taken from the Corvette Parts and Illustration Catalog used by Chevrolet dealers.
QUEESTIONS:
Thanks,
Dennis Decina
1- All the paint manufacturers colors were consistent within their nomenclature. They often changed names for the same color different models and years, but never their own manufacturers code, no matter what year. Answer is no.
2-None of the chip books you'll find has that info. The only place to find it is from an original PPG mixing station. I'm sure there are an many old time parts store that mixed and sold PPG paint that may still have the old books with the formulas.
I'm sure PPG has the formulas somewhere, but getting it may be another story.
The 1968 Corvette Bronze color is definitely a different hue of Bronze. In my opinion, it's more brown than the 1970 color. The 1970 Corvette Bronze was also a "Firemist" color, and as such I believe it had an additive to achieve that status. The paint formulas are distinctly different.
I do not have assess to my research or pics right now, but if you want to see some pics of the '68 Corvette Bronze, I can post them this evening.
Received 2,878 Likes
Hi Dennis,
I think you're wise in choosing lacquer for your car.
I would recommend that you just buy as small an amount of paint as possible once you find the proper formula.
On a color as unusual as the Corvette Bronze I think spraying some test panels before you buy 2 gallons of paint would be worth the effort involved.
I'd want to compare the panels to a known original 70 bronze car before spending the rest of the $$$ on the paint.
It would be a shame to go through the work and expense of a lacquer repaint and not have the color be just right.
Good Luck!
Regards,
Alan
Good Luck!
Regards,
Alan
