Help! P/S control valve stud spins.
Old 01-01-2015, 11:47 PM
derek15003
derek15003's Avatar
Default Help! P/S control valve stud spins.
I have under taken my 69' Stingray restoration. After 40 years of sitting outside things were very interesting coming apart... (to say the least). However, after a big parts order I was getting some of my front power steering core pieces disasembled when right away I noticed that the pitman arm was flopping around on the control valve body. So after everything eles came off this was my final inspection.
Right now the problem is that the ball stud just spins inside of the control valve. Does any one have a tip that will help remove it. Hopefully one that does not include damage to the valve unit itself.
Thank You.
Old 01-02-2015, 04:16 AM
Sacred Steel
Sacred Steel's Avatar
Try using one of those forks used to separate ball joints. Wedge it in there to put some tension on the ball stud while turning the nut.
Old 01-02-2015, 04:49 AM
derek15003
derek15003's Avatar
I'll give it a shot tomarrow. I tried my picklefork that I used on Ball joints.. It was just a little too big. I am going to stop at autozone tomarrow and get something smaller. Thank you for the reply!!
Old 01-02-2015, 12:36 PM
AzMotorhead
Support Corvetteforum!
AzMotorhead's Avatar
Get a nut splitter and split the nut. Then get pitman arm seperator to get it out of the pitman arm.
Thing is if you use a pickle fork ,more than likely you will damage the center link. Where that pivot ball rides is pretty thin casting
Old 01-02-2015, 04:02 PM
derek15003
derek15003's Avatar
Thanks everyone. Breaking the nut would have been much easier. But I didn't have one so I used a 3 inch cut off wheel and cut the nut in. Then broke it with a chisel. Done. Thanks everyone !
Old 01-03-2015, 02:47 PM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
I haven't seen a 'spinning stud' since watching John Travolta in "Saturday Night Fever".
To Help! P/S control valve stud spins.
Quick Reply: Help! P/S control valve stud spins.
