Why would this be in my oil pan?
Old 04-19-2015, 07:06 PM
MMJ
MMJ's Avatar
Default Why would this be in my oil pan?
I had a small knock at startup on my L46. I dropped the pan to see if I saw anything unusual. When I was cleaning it out I found this washer. It's very thin. Could be a spring washer or a shim. Anybody know where it could have come from or how it could have got in the pan? Thanks for any help.
Old 04-19-2015, 07:44 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
Without the thickness of the washer and the measurements of it....it is hard to say. OBVIOUSLY it fell into the engine...but it can possibly be a washer used at the bottom of the shaft of the distributor that is or can be installed above the gear on the distributor. SO there is no way that this washer can 'fall off' the distributor....especially if the gear is proper pinned to the shaft.
DUB
Old 04-19-2015, 07:59 PM
MMJ
MMJ's Avatar
Originally Posted by DUB
Without the thickness of the washer and the measurements of it....it is hard to say. OBVIOUSLY it fell into the engine...but it can possibly be a washer used at the bottom of the shaft of the distributor that is or can be installed above the gear on the distributor. SO there is no way that this washer can 'fall off' the distributor....especially if the gear is proper pinned to the shaft. DUB
The diameter of the hole is 13/32 or 7/16. The o.d is 11/16. Thanks for the help.
Old 04-19-2015, 08:17 PM
76vette1
76vette1's Avatar
A washer for a head bolt that was dropped during assembly?
Old 04-19-2015, 08:48 PM
Cool95vette
Cool95vette's Avatar
It couldn't have fallen off of anything. It had to be dropped in when the motor was apart.
Old 04-20-2015, 06:11 PM
DUB
DUB's Avatar
Unless someone was adding the washer to the head bolts...I am not aware or have ever seen washers for head bolts on cast iron heads.
It got dropped into the engine at one time or another....because there is nothing that it can fall off of. I can not see what it could have fallen off of except from what I had mentioned earlier....but it did not fall off of the distributor...it got dropped into the engine.
DUB
Old 04-20-2015, 06:24 PM
Red08
Red08's Avatar
Received 1,441 Likes on 780 Posts
it definately doesn't belong there.
Old 04-20-2015, 06:55 PM
MMJ
MMJ's Avatar
Thanks for the help guys. That makes me feel better.
mchar
mchar's Avatar
It's a clue. Whatup w/ the 'small knock'?
Old 04-20-2015, 07:39 PM
jnb5101
jnb5101's Avatar
It was probably dropped down the distributor shaft hole. Don't ask how I know.
Old 04-20-2015, 08:33 PM
redvetracr
redvetracr's Avatar
thats awfully thin for a head bolt washer
Old 04-20-2015, 08:42 PM
LS4 PILOT
LS4 PILOT's Avatar
Originally Posted by mmj
i had a small knock at startup on my l46. I dropped the pan to see if i saw anything unusual. When i was cleaning it out i found this washer. It's very thin. Could be a spring washer or a shim. Anybody know where it could have come from or how it could have got in the pan? Thanks for any help.
pfm
Old 04-21-2015, 03:46 PM
dochorsepower
dochorsepower's Avatar
Hmmm, a left handed washer.
Old 04-21-2015, 05:42 PM
DUB
DUB's Avatar
YEP...when a distributor is out....it is funny how something can find its way down into the block through this hole. I KNOW it all too well also. SO...EVERY TIME I take out a distributor...I have a plastic plug I put in the hole the second I get the distributor out of it.
.....and I have never come across any washers under head bolts for this era of Corvette.
DUB
Old 04-21-2015, 05:49 PM
leadfoot4
leadfoot4's Avatar
Received 1,343 Likes on 1,094 Posts
Sure looks like a distributor shim, to me.....
Old 04-22-2015, 08:00 AM
MMJ
MMJ's Avatar
YEP...when a distributor is out....it is funny how something can find its way down into the block through this hole. I KNOW it all too well also. SO...EVERY TIME I take out a distributor...I have a plastic plug I put in the hole the second I get the distributor out of it. .....and I have never come across any washers under head bolts for this era of Corvette. DUB
Good idea!
Old 04-22-2015, 08:59 AM
Sigforty
Sigforty's Avatar
Cruise-In IX Veteran
To Why would this be in my oil pan?
Old 04-22-2015, 11:30 AM
REELAV8R
REELAV8R's Avatar
Received 1,034 Likes on 852 Posts
Originally Posted by LS4 PILOT
pfm
LOL. Do you have to be a pilot to get that?
Old 04-22-2015, 11:53 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
Must have been dropped in the pan during engine assembly. Not a problem, though; it couldn't be sucked up through the suction screen, and there's not enough oil turbulence in the sump to cause it to wander from the bottom of the pan. It would just sit there forever without causing any issue.
If you heard a "knock", it wasn't because of that washer.
Old 04-22-2015, 12:38 PM
leadfoot4
leadfoot4's Avatar
My curiousity finally got the best of me, and I walked out to the garage, and dug out a package of Mr. Gasket distributor shims, that were buried in the tool box. Using just a ruler, not calipers, my measurements showed the shim to be 7/8" OD, 1/2" ID.....
Quick Reply: Why would this be in my oil pan?
