Tri Power Lines
Old 09-08-2015, 10:04 AM
ggroller
ggroller's Avatar
Default Tri Power Lines
I've been chasing a fuel leak at the center carb all Summer and the line fitting to the carb is a bit boogered up so It's time to take the time to fix it correctly.
Has anyone ever ordered from this guy?
http://www.ebay.com/itm/1968-69-7PC-FUEL-LINE-SET-CORVETTE-427-TRI-POWER-400-435HP-CORVETTES-NEW-SUPER-/261722106028?hash=item3cefda68ac&vxp=mtr
Old 09-08-2015, 10:27 AM
69FASTFUN
69FASTFUN's Avatar
I ordered mine from Paragon and they fit perfect and they were $54.00
Old 09-08-2015, 12:34 PM
ggroller
ggroller's Avatar
Thank You.
Regular steel or stainless?
Old 09-08-2015, 12:41 PM
gbvette62
gbvette62's Avatar
Received 2,069 Likes on 1,338 Posts
Stay away from stainless, especially for a multi piece fuel line, like the 3x2 uses. They're almost impossible to get to seal, and difficult to work with. The regular TBW steel ones will last just about forever, especially with the amount of use and weather these cars see.
Old 09-08-2015, 02:35 PM
1Fordman
1Fordman's Avatar
Good advice. Tried a set of SS at first on the l-71, would not seal. TBW steel lines no problem.
Old 09-08-2015, 08:20 PM
tfringo
tfringo's Avatar
Default Hello,
Leaks like this….. always look really closely at the tubing flange. They like to form hairline cracks that leak ever so slightly. There are lots of cars that burn to the ground because of this. Don't over tighten the connections.
1968 69 7pc Fuel Line Set Corvette 427 Tri Power 400 435HP Corvettes New Super | eBay
Old 09-08-2015, 09:10 PM
dugsgms74
dugsgms74's Avatar
Ive had problems making these fitting seal in the past but then used flare-savers, worked great!
http://www.amazon.com/Flare-Gasket-Copper-PK-10/dp/B002KLKSSQ/ref=sr_1_1?ie=UTF8&qid=1441761003&sr=8-1&keywords=flare+gaskets http://www.amazon.com/Flare-Gasket-Copper-PK-10/dp/B002KLKSSQ/ref=sr_1_1?ie=UTF8&qid=1441761003&sr=8-1&keywords=flare+gaskets
Old 09-09-2015, 06:23 AM
ggroller
ggroller's Avatar
Thanks for all the replies.
Paragon was on a 12 day back order so I ordered the steel lines from Corvette Central.
To Tri Power Lines
Quick Reply: Tri Power Lines
