Battery cables for 69
Old 09-10-2015, 12:11 PM
SB64
Support Corvetteforum!
SB64's Avatar
Default Battery cables for 69
I have the cables for top post battery. I noticed that it appears the AIM shows side mount cables. Sticking with originality which one is it.
Anybody, please help so I may continue my restore.
ZIO
Old 09-10-2015, 12:15 PM
dan1495
dan1495's Avatar
2016 C3 of Year Finalist
My late production 69 had side post terminals.
Old 09-10-2015, 12:20 PM
JC68
JC68's Avatar
ZIO
Vin 22,000 is the approximate switch from the top to side post batteries in 1969.
John
Old 09-10-2015, 08:48 PM
jhudec
jhudec's Avatar
Should be top mount spring ring cables to be correct.
Old 09-10-2015, 10:02 PM
gbvette62
gbvette62's Avatar
Received 2,031 Likes on 1,316 Posts
John
GM switched over to side post cables at the start of the 1970 model year production for all of their vehicle lines.
Because 69 Corvette (and Camaro) production continued basically unchanged until December of 69, battery cable usage was split on them. Cars built through June used the older spring ring cables, while cars built after that point, got side post batteries and cables.
Old 09-11-2015, 05:51 AM
SB64
SB64's Avatar
Thanks to all the feedback. Just wanted to make sure I had the right cables since the positive cable needs to go in first before any insulation and would be a real bear to change out later.
ZIO
Old 09-12-2015, 08:13 AM
SB64
SB64's Avatar
Default Cable
Anybody out there who has a picture of the positive battery cable and how sharp the bend is by the shifter area. This would be very helpful or can look at mine in my post to see if it is close.
Thanks in advance.
ZIO
Old 09-12-2015, 08:42 AM
Don Rickles
Don Rickles's Avatar
2017 C3 of Year
gb,
Didn't this effect the direction of the facing of the batteries? Terminals facing forward vs. top rear? IIRC???
WB
Old 09-12-2015, 08:51 AM
SB64
SB64's Avatar
Originally Posted by War Bonnet
gb,
WB
That was going to be my next question, good call War Bonnet! Right now I have the battery post facing forward towards the drivers seat.
ZIO
Old 09-12-2015, 08:53 AM
Don Rickles
2017 C3 of Year
ZIO
Think it's called out in the JG?
Old 09-12-2015, 10:31 AM
gbvette62
gbvette62's Avatar
The side post terminals face forward, according to the 69 AIM.
Old 09-12-2015, 10:43 AM
SB64
SB64's Avatar
How about top post gbvette62?
Old 09-12-2015, 11:04 AM
ddawson
ddawson's Avatar
Still forward. + is on the passanger side
Old 09-12-2015, 11:10 AM
SB64
SB64's Avatar
Thanks ddawson, at least I got that resolve. Now I just have to figure out how much of a bend there is in the positive battery cable.
ZIO
Old 09-12-2015, 12:58 PM
Red Vert 02
Red Vert 02's Avatar
ZIO
Hi R,
Here is a picture of my late 69 battery compartment. I use the Delco for everyday and a repo for judging. Not much slack in the cables.
Old 09-12-2015, 01:07 PM
Red Vert 02
ZIO
Hey R,
Here is a pic of the battery box from when I was cleaning and touching up the black out when installing the repo battery for a show.
Old 09-12-2015, 01:25 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi r,
Here are a couple of pictures of the 71 positive battery cable crossing from the left side of the underbody to the right on it's way forward to the starter. The pictures are looking forward toward the transmission with the driveshaft removed.
It's shown in the 71 AIM on UPC12 Sheet A10.
Regards,
Alan
Old 09-12-2015, 01:50 PM
SB64
SB64's Avatar
Originally Posted by Alan 71
Hi r,
Regards,
Alan
Thank you Alan for taking the time to find those pictures. It makes things a little clearer.
R
To Battery cables for 69
Quick Reply: Battery cables for 69
