how to pain the brake fluid reservoir cap?
Hi, I have a c3 70 vette and the fluid reservoir cap has some rust and wear (see image attached). Does anyone know what type of paint I need to re-paint it?
Thank you
Siol.
Thank you
Siol.
For the price of them, just buy a new one. But, shoot the new one with clear lacquer before you install it. The yellow chromate color of the new one will fade away unless you coat it.
Received 1,470 Likes
Cruise-In II Veteran
Looks like your cap already has a coat of aluminum on it.
Be nice, guys. The OP is trying to make it look better. Not everyone has a show car.
Received 2,878 Likes
Hi s,
It appears from your posts that you're working on a 70 and a 79 at the SAME time.
Hats off to you!!!!!
Good Luck!
Regards,
Alan
Good Luck!
Regards,
Alan
This doesn't cost much more than a can of paint.
http://www.summitracing.com/int/part...3/applications
Hi S,
NO!
Because you WROTE this……
"Hi, I have a c3 79 vette and I found out the passenger door at the feet is hanging (see image)."
Regards,
Alan
NO!
Regards,
Alan
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
I have that one and the same issue. To fix it took like a minute. I just gently bent the bottoms of the bales where they hook into the MC. Instead of the 90* bend on the ends, I made it a bit more than 90*. Worked for me.
I have one. You just have to bend the bails a bit to get them to press down on the cap a bit more. The supplies bails are brittle though and have a tendency to break when you try to bend them. I ended up using the stock ones on the new lid.
