Steering column lower trim piece question
I have a question for the group, it is in regards to the steering column lower trim piece and how it attaches on my ‘74. There are three screw holes in the trim piece, two toward the front of the trim piece that connect to the instrument cluster/dash and one that attaches to the steering column. My issue is with the screw that is supposed to attach the trim to the steering column. There is only a slot in the column where the screw would go that is about a ¼” wide and an 1 ½” long. I am thinking a plastic nut of some type should be in the slot. If someone could shed some light on how the trim piece attaches to the steering column and where I can get the parts it would be much appreciated.
Regards,
Robert
Regards,
Robert
There is a plastic insert nut, 'similar' in appearance to these, that is inserted first for the screw to go into.
Most auto parts stores will have small packages of them, some in various sizes. Even a small plastic drywall insert can be made to work. File flats on opposite sides, cut it to length and insert it into the slot.
Good luck... GUSTO
Good luck... GUSTO
mikem350 (12-07-2016)
Regards,
Robert
Regards,
Robert
Received 2,878 Likes
Hi Robert,
Everyone's dancing around what was used in 74….
This is the retainer for one screw that's slides in the slot in the column of my 71.
Regards,
Alan
Regards,
Alan
So there is no clip, just screwed into the hole in the strap. Mine must have been stripped because there was a screw clip on mine. I guess if it is stripped you just use a clip. Just keep in mind short screw to avoid wires.
