Newbie Needs Help With Gauges
Old 03-30-2005, 06:13 AM
qwk vette
Cruising
qwk vette's Avatar
Default Newbie Needs Help With Gauges
I have a 77, and have some gauge problems. My oil pressure gauge used to work intermittently but no longer. The clock does not work. The fuel gauge bounces around when the tank is not full. Speedometer needle bounces and odmeter does not work.
Is the oil pressure gauge just a power wire, then wire to the sending unit? What other fixes do I need?
Thanks for all your help
Old 03-30-2005, 07:46 AM
62fuelie
62fuelie's Avatar
On the speedo, you can probably cure the bouncing problem by pulling the cable and treating it to a clean/lube. To fix the odometer, it will have to be pulled and likely taken to a speedometer shop. As to the oil pressure gauge, try grounding the sender wire momentarily with the ignition on. It should read full scale. if so, the sender is likely bad.
Quick Reply: Newbie Needs Help With Gauges
