4 Speed Linkage Adjustment
there's a slot in the linkage that a "tool" slides into. this aligns the shifter plates. then the linkages are set so that the clevis and attachment points on the trans just line up. this "tool" is nothing more than a flat piece of steel about 1/16 thick and 5/8 wide and 2 inches long. any shop manual will give detailed info.
available in the shop Manuel (at least it was in the factory manual for my 72 ...
Bob G.
64 72 & 98 Verts
76 & 79 Coupes
For the 63-68 muncie 4 speeds..."construct a block 1/8" gauge by 41/64" wide" (mine was about 3" long)....wiggle it into the shift lever bracket assembly and then do your adjustments. Chiltons has a reasonable description of the procedure.
Good Luck
