76 hot air to electric choke conversion
Hello...considering converting over to an electric choke from my 76 hot air....how does the electric choke work and how much does it cost?......Thanks,Pete
St. Jude Donor '08
Are you going to replace the carb? If thats in the plan, just buy one with it and hook the choke wire to a switched hot wire. If not, what kind of carb is on there now?
Are you going to change the complete carb.or do you just want to install the choke in the housing? I'm pretty sure if it's a quadrajet you can buy a electric choke coil for a newer year then all you have to do is run a hot wire to the coil but when you run the wire make sure that it is hot when key on. I hope this answers your question. The price for the choke coil should be around 20 to 25 dollars
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,926 Likes
Lars
Just take an idiot light and touch the wiper motor wires. Whichever wire lights the idiot light when you tuirn the ignition on is good to use.
One question about the electric choke. Let's say you're having trouble starting the engine, perhaps it cranks over but doesn't start. As you're working on the engine, I would imagine the electric choke is getting hotter and hotter and eventually will open up the choke trottle plate (whatever it's called). Now with the choke in the open position, aren't you going to have even more trouble getting you're balky engine to start?
My ZZ4 carb has an electric choke and I thought about putting a small switch on the choke heater wire. Haven't done it though since my engine fires up immediately. (Thanks to all the distributor timing and vacuum advance learning from reading forum posts.)
