Info on GMPP 12367712 Aluminum Heads
Old 01-29-2008, 07:16 AM
69396Chevy
69396Chevy's Avatar
Default Info on GMPP 12367712 Aluminum Heads
Hi Guys,
Can anyone tell me about the GMPP 12367712 heads. They are the GM fast burn heads but not the newer casting number. Thinking of trading some stuff for these and want to make sure there isnt anything special about these I need to know. Can they work with an old school tyle intake or just a vortec. Are these the same as the other 12464298 part number?
Chris
Old 01-29-2008, 09:08 PM
gingerbreadman1977
gingerbreadman1977's Avatar
i dont have access to the part numbers but i have gm fast burn heads. i run them with a vortec air gap manifold. i thought fast burns were all vortec with raised runners so if thats the case you will def need vortec manifold.
Old 02-11-2008, 05:35 PM
luerja
luerja's Avatar
Default heads
Cast #12367713 is nothing more then a hardened version of cast #12367712. Cast #12367713 was being used currently on a high-volume production basis. The origial prototype cast #12367712 was too soft to be able to hold up to this.
12464298 is the new high-volume production number of the same head.
Old 04-02-2013, 04:14 PM
keithnh
4th Gear
keithnh's Avatar
What is too soft about 12367712? Just got a used set that looks nice Im going to possily carve up for a 302 conversion. (52cc)
To Info on GMPP 12367712 Aluminum Heads
Quick Reply: Info on GMPP 12367712 Aluminum Heads
